Fuel injectors - Mustang Evolution
Old 01-25-2013, 11:04 PM   #1
Kstangs2002's Avatar
Fuel injectors
Wich fuel injectors should i go with i would like something better than the stock
Kstangs2002 is offline   Reply With Quote
Old 01-26-2013, 12:31 AM   #2
BigB227's Avatar
Well not knowing what bolt ons you have so far and if you don't plan on going FI I believe 24 lb injectors should be good. I've heard that if you go higher that you need a bigger fuel pump and such but idk if that's true
BigB227 is offline   Reply With Quote
Old 01-26-2013, 01:50 AM   #3
Venomouz831's Avatar
If you're not FI then don't change em waste of money
)02 Gt, Founder of WE2G
Old 01-26-2013, 01:56 AM   #4
WheelStander's Avatar
+1
Induction: Kenne Bell | wHp: 515 Tq: 503 | 1/4 Mile:11.09@123
WheelStander is offline   Reply With Quote
Old 01-26-2013, 07:21 AM   #5
Im switching the manifold cause the plastic of the back broke off where it connects to a hose so that part is not replaceable so i have to change the whole manifold by removing the fuel injectors do i have to change the o rings on them
Old 01-26-2013, 07:23 AM   #6
Poopyhead44's Avatar
The o rings are super cheap I would change them just because
Poopyhead44 is offline   Reply With Quote
Old 01-26-2013, 10:32 PM   #7
cliffyk's Avatar
Read the fuel injector section of the Beginner's Guide to Bolt-ons sticky...
Old 01-26-2013, 10:38 PM   #8
bottlefed04's Avatar
Make sure you get a tune and a calibrated maf for bigger injectors
bottlefed04 is offline   Reply With Quote
Old 01-26-2013, 10:53 PM   #9
cliffyk's Avatar
If you have a proper tune you do not need a "calibrated" MAF, they are kludges left over from 20 years ago when re-tuning was very difficult and/or impossible--read more about why they suck here...
12:24 AM
