wont start - Mustang Evolution
Old 01-26-2013, 10:46 AM   #1
98GTCONV's Avatar
wont start
Tried to start my car today and it wont even turn. I usually shake the shifter in park and it finally cranks. Im pretty sure its something with the transmission linkage cable or something. Well, since I can't move it, is there any way I can fix this myself?
98GTCONV is offline   Reply With Quote
Old 01-26-2013, 11:36 AM   #2
Tyoung68's Avatar
Your shifter is stuck ?
Old 01-26-2013, 11:38 AM   #3
98GTCONV's Avatar
Its an auto. I can shift thru them, wont start in park or neutral.
Old 01-26-2013, 11:44 AM   #4
BigB227's Avatar
It's your transmission range sensor, mine was going out an I replaced it and fixed all my starting issues. Look in rock auto. Com
BigB227 is offline   Reply With Quote
Old 01-26-2013, 11:46 AM   #5
98GTCONV's Avatar
Did yours start when you shook the shifter sometimes?
Old 01-26-2013, 11:48 AM   #6
BigB227's Avatar
My car would do it sometimes and I had to run it through the gets and put it back in park for it realize it was in park to start. Plus when your down there replacing it you have to adjust your shift cable to the transmission. I'd check on the cable first but I'm pretty sure that it could be the range sensor not telling the computer your in park
---------- Post added at 01:48 PM ---------- Previous post was at 01:48 PM ----------
Gears* not gets
Old 01-26-2013, 11:50 AM   #7
98GTCONV's Avatar
Im guessing the car will need to be on a lift or jackstands?
Old 01-26-2013, 11:55 AM   #8
98GTCONV's Avatar
I replaced transmissions last year, didn't pull anything off the old one, maybe I should try that sensor on the old one to see if it does the trick?
Old 01-26-2013, 11:55 AM   #9
BigB227's Avatar
Jack stands would be ideal lol
08:21 PM
