Thermostat help - Mustang Evolution
Old 01-26-2013, 05:16 PM   #1
Doe_Rae_mi's Avatar
Thermostat help
Hey guys my water to cool my engine down is leaking from the themostat. I will be parking my car because of this but any ideas on how to fix this? It's very minor but water is still seeping out of it
Old 01-26-2013, 05:19 PM   #2
deadsp0t's Avatar
Just go get a new thermostat, gasket and some RTV sealant.. Make sure all the surfaces are super clean.
It's an extremely easy swap.. Doing mine tomorrow.
That's unimpressive
Old 01-26-2013, 05:21 PM   #3
Doe_Rae_mi's Avatar
How much would it cost? Could I get them from autozone?
Old 01-26-2013, 05:23 PM   #4
deadsp0t's Avatar
Yup, like $10 for the T-Stat $5 for the gasket and $7.50 for the RTV..
Biggest thing is to make sure the surfaces are spotless!!!! If you have a Haynes or Chiltons manual there are details on the repair in it..
That's unimpressive
Old 01-26-2013, 05:31 PM   #5
Doe_Rae_mi's Avatar
Okay thanks!! And do I really need that rtv? That junk is messy
Old 01-26-2013, 05:32 PM   #6
deadsp0t's Avatar
Yes!! You do not need a lot but it will ensure you don't have any leaks and don't have to do it twice! It comes in smaller tubes for single use, will save a couple bucks.
That's unimpressive
Old 01-26-2013, 05:34 PM   #7
Doe_Rae_mi's Avatar
I actually have a leftover tube of it . I just wanted to keep it as clean as possible haha
Old 01-26-2013, 05:36 PM   #8
deadsp0t's Avatar
once it's good and dry you can use a razor to trim it up nice and clean! That's how I roll lol
That's unimpressive
Old 01-26-2013, 05:39 PM   #9
Doe_Rae_mi's Avatar
Lmao thanks for the help man
Old 01-26-2013, 05:41 PM   #10
deadsp0t's Avatar
Np, just take your time and you shouldn't get too messy also a little extra coolant on hand will be good too.
That's unimpressive
Old 01-26-2013, 09:52 PM   #11
cliffyk's Avatar
Can you get a photo of the thermostat housing and surrounding area? It is very common on our cars that somewhere around 100k miles the inner wall of the plastic flange's coolant passage (between the t-stat housing and the head) will deteriorate and allow the formed sealing ring to bulge out--allowing coolant to leak.
It looks like this when it fails:
When mine failed I disassembled the aluminum crossover and manifold; scraped it all as clean as a dinner plate, removing all deteriorated plastic and other crud; degreased it all with denatured alcohol, and reassembled it using JB-Weld with no gaskets--that was 35k miles ago:
(I also bought a new FRPP manifold which sits in my attic, as insurance that the JB-Weld repair will never fail.)
Get a photo of it if you can, if it has failed as described above it will be obvious...
Old 01-27-2013, 10:27 AM   #12
Doe_Rae_mi's Avatar
Can u guys give me a guide on how to install the new one??
11:38 AM
