Engine Gaskets - Mustang Evolution
Old 01-26-2013, 10:12 PM   #1
Mustang_Madness's Avatar
Engine Gaskets
I'm pulling my engine because i need to inspect everything inside. I want to replace All the gaskets while im down there as well. can anyone tell me if this set would work? Ford Racing Complete Mustang Engine Gasket Kit (289/302/5.0L/351W) M-6003-A50 - Free Shipping!
I know its up to a 95 but it also says 289 engines. and i have a 98 engine. can someone direct me as to where i could get a full engine gasket set and things i should do or look at while im down there? thanks a ton
K&N CAI, Cobra 18" Rims, Cobra Brakes, More Mods to come!
Mustang_Madness is offline   Reply With Quote
Old 01-26-2013, 10:32 PM   #2
bottlefed04's Avatar
Bro you have a 281 not 289
bottlefed04 is offline   Reply With Quote
Old 01-26-2013, 10:34 PM   #3
98vertgt's Avatar
+1
98vertgt is offline   Reply With Quote
Old 01-26-2013, 10:59 PM   #4
What year mustangs have the 289 then? Where do i find the gaskets then? I cant find them anywhere...
Old 01-26-2013, 11:06 PM   #5
You can't find a 4.6gasket set?? And i believe 64 to 73
---------- Post added at 12:06 AM ---------- Previous post was at 12:05 AM ----------
And summit has them. Or call a ford dealer
Old 01-26-2013, 11:23 PM   #6
I see alot of people say 289s when its a 281 i guess. I barely see stuff for 281s. But ill check summit racing..
Old 01-26-2013, 11:28 PM   #7
You can also use a 5.4 330ci gasket set as well on the 4.6
Old 01-27-2013, 12:04 AM   #8
Alright well I looked on Summit Racing and I guess i need to buy 2 seperate Sets to completely get what i want.. Anyways, Anything i should look at and inspect while im down there?
Old 01-27-2013, 12:11 AM   #9
Also, Should i just get PI heads and Intake? im getting a little over 1000 in tax returns and could use that i think..
Old 01-27-2013, 02:43 PM   #10
Id definitely do the pi swap. You gain a lot of power from it. It bumps compression up to 10:1 i believe
Old 01-27-2013, 10:07 PM   #11
1996mustang's Avatar
10.54:1 if i rememn
02:39 PM
