How to tell what engine you have. - Mustang Evolution
Old 01-26-2013, 10:21 PM   #1
Mustang_Madness's Avatar
I got my 96 Mustang a year back, and i was told it has a 98 V8 in it. I want to verify that because originally it had a V6 in it. I want to know 100% that it is what it is. not a 2000 4.6 or something like that. How can i do that?
K&N CAI, Cobra 18" Rims, Cobra Brakes, More Mods to come!
Mustang_Madness is offline   Reply With Quote
Old 01-26-2013, 10:25 PM   #2
1slosix's Avatar
Post a pic of your engine bay
carving corners like a boss
Old 01-26-2013, 10:33 PM   #3
cliffyk's Avatar
^+1...
Old 01-26-2013, 11:00 PM   #4
You can tell just from that?
Old 01-26-2013, 11:02 PM   #5
98vertgt's Avatar
Yeah
98vertgt is offline   Reply With Quote
Old 01-26-2013, 11:10 PM   #6
A picture is worth a thousand words
Old 01-26-2013, 11:19 PM   #7
The dude before me did some stuff to it as well. Dorman intake manifold, 75 mm bbk tb, and K&N CAI...
---------- Post added at 01:19 AM ---------- Previous post was at 01:18 AM ----------
I have the engine stripped down pretty much because im in the process of taking it out...
Old 01-26-2013, 11:20 PM   #8
1slosix's Avatar
Dorman makes oem replacement intakes so we can still figure it out.
Old 01-26-2013, 11:23 PM   #9
Rich04's Avatar
Could also count the spark plugs/cords
Rich04 is offline   Reply With Quote
Old 01-26-2013, 11:25 PM   #10
You don't understand! I Know its a V8. Lol obviously. But i need help on the year it was made! Like a vin for the engine or id number or something ya know??
Old 01-26-2013, 11:26 PM   #11
Rich04's Avatar
Ahhh , i see
Old 01-26-2013, 11:27 PM   #12
1slosix's Avatar
So post a pic lol we can tell you
Old 01-26-2013, 11:31 PM   #13
+10000
Old 01-26-2013, 11:56 PM   #14
cliffyk's Avatar
The '96 though '98 GT modular 2V engines had the wasted spark EDIS ignition system, using two coil packs and plug wires:
The '99 through '04 use the coil-on-plug (COP) ignition:
It will be "in-your-face" obvious the moment you open the hood...
Old 01-27-2013, 12:00 AM   #15
1slosix's Avatar
Yeppers...
Old 01-27-2013, 12:03 AM   #16
oh alright. well it is in the 96-98 range then. i do have 2 coil packs and plugs. Thanks cliffyk. Any way to know what year it is? or am i just out of luck on that aspect?
Old 01-27-2013, 12:11 AM   #17
1slosix's Avatar
Find the code on the block is your best bet
Old 01-27-2013, 12:17 AM   #18
Thanks! i appreciate it
Old 01-27-2013, 12:24 AM   #19
cliffyk's Avatar
That would be the only way to nail down the year of manufacture, however it really doesn't matter for buying parts stock or aftermarket as from '96 through '98 they were all the same...
Old 01-27-2013, 12:43 PM   #20
1996mustang's Avatar
8th digit of the vin if its a x its a gt from factory, and 10th digit dictates what year it is.
Old 01-27-2013, 02:53 PM   #21
cliffyk's Avatar
I believe that is not the issue, he already knows the car was a V6 from the factory, and now wants to know specifically what year the NPI 2V that's in there was made.
Old 01-27-2013, 04:52 PM   #22
Exactly.. Any way to tell?
Old 01-27-2013, 05:01 PM   #23
1slosix's Avatar
i just told you lol....look for the stamp on the block it's like you tune me out
Old 01-28-2013, 04:50 PM   #24
I didnt know what to read from it. But i have an idea of what to look for so ill check it once i pull the engine. Thanks though.
Old 01-28-2013, 05:35 PM   #25
cliffyk's Avatar
I am not sure I understand what it is you wish to know? We have established that is it a NPI engine (having dual coils and plug wires), and that all '96 to '98 NPI engines were for any repair/build purpose identical.
Why is the specific year of manufacture so important?
Old 01-28-2013, 05:40 PM   #26
garbill2003's Avatar
X2 the block doesn't have to be the same year as long as it's a 4.6 2v
garbill2003 is offline   Reply With Quote
Old 01-28-2013, 05:43 PM   #27
cliffyk's Avatar
I give up...
Old 01-28-2013, 05:53 PM   #28
1996v6stang's Avatar
Originally Posted by cliffyk View Post
I give up...
Lol
1996v6stang is offline   Reply With Quote
Old 01-28-2013, 08:30 PM   #29
I just want to know forsure what my engine is. I'm not pulling it just for the sole purpose of knowing. I have alot of maintenance work that im doing as well, I just would rather know if the guy told me the truth or not. He's lied about some stuff already so i cant take his word for it.
Old 01-28-2013, 11:18 PM   #30
DutchManDann's Avatar
Okay so first off, the ignition system does not necessarily decide the year of the engine. If he swapped a PI engine, he could have kept the coil packs/wires.
That being said, it is more than likely a Non-PI engine. Especially if it still has the coil packs.
I did a 98 to 2001 engine swap. Here's a comparison between the two engines. Note that I converted to COPS when I did my swap.
You can look at the alternator, which is differnet between the two.
The oil fil cap on the valve covers is different.
One piece on information that could help, the 98 is the only SN95 with a return fuel line. This means there are two fuel lines connected to the fuel rails on top of the engines. This may or may not help you, as if it is a 98 engine, it is rather unlikely that the person doing th swap bothered to keep the return fuel line. It would have been quicker to just swap over the fuel rails from the 96 engine.
If your engine looks indentical to the top photo in my picture, then you probably have a 98. But it could be a 97 or 96...it's hard to tell
DutchManDann is offline   Reply With Quote
Old 01-29-2013, 05:34 AM   #31
cliffyk's Avatar
Read the OP's original post, "He" took out a V6 and installed a V8, there were no coil packs to be preserved...
Old 01-29-2013, 06:12 AM   #32
I was just saying that the person who did the swap could have preserved the coil pack system, as in not convert to COPS, or they could have converted to COPS. Not that they preserved the coil packs from the V6. I was posting pictures of both of my engines so he could try to see what his current engine is.
Regardless, it is pretty easy to tell if it is a V6 vs V8, and if it is a NPI or PI motor. Which as you guys already said, if it is a NPi motor the year is insignificant. All NPI motors have the exact same set up (same flywheel, valve covers, etc) so it would be hard to tell the difference anyways.
Old 01-29-2013, 07:56 AM   #33
Well then it Is a 98! That helped me alot! I do have a return fuel line on the rail as well and it looks exactly like the picture. Now i know forsure what im dealing with! Thanks again! Also, im replacing the headgaskets in a couple of days, should i just get pi heads, intake? Or save up for something like trickflow?
Old 01-29-2013, 09:05 PM   #34
Well if you're doing the headgaskets, you might as well do PI heads. You can save up for the trickflow heads but personally, i dont think it is worth it. For the price you would put in the heads you could almost supercharge your car.
If you just did PI heads/cams/intake you would see a gain of ~40-50 horsepower, which is quite a jump.
Glad I could help!
Old 01-29-2013, 10:23 PM   #35
How much are pi heads and intake? I dont think id have enough right now for cams and i want to get my stang up for the summer. Its been down for like 9 months now
08:44 AM
