Tranny problems?? Please help - Mustang Evolution
Old 01-27-2013, 10:08 AM   #1
Kbasham5's Avatar
Hey guys hoping to get some help here. I have a 2001 GT with TR-3650 transmission. Was driving it last night when all of a sudden while backing out of a driveway I was putting it in 1st gear and there was a terrible squeling noise coming from transmission and I could barely get it in gear. It's still doing it and there is a lot of play now in the clutch pedal. With it in gear with the clutch pedal pushed in it is still squeling and wanting to pull like the clutch isn't engaged. Any help would be appreciated.
Kbasham5 is offline   Reply With Quote
Old 01-27-2013, 10:31 AM   #2
OK honestly I have like ZERO experience with manuals ,but to me it sounds like your clutch is toast. Good luck
Old 01-27-2013, 10:32 AM   #3
1996v6stang's Avatar
Tob sounds like it is ****ed up.
1996v6stang is offline   Reply With Quote
Old 01-27-2013, 10:45 AM   #4
Kbasham5's Avatar
I was thinking TOB but just wanted to get other opinions.
Old 01-27-2013, 01:38 PM   #5
IanM's Avatar
Might check your clutch cable, as they get older they stretch out and it might have slack in it. I had issues with my 87 GT like that, ended up needing to replace the clutch quadrant in my scenario, but I don't know if that applies to yours. Just an idea of something to check.
2011 Grabber Blue GT California Special, 3.73 Gears, 6-Speed Manual, Steeda CAI, Steeda 93 tune, aluminum driveshaft (The Driveshaft Shop Co.), MGW shifter, Roush axle-back exhaust, Roush Side Rocker Panel Splitters, Ford Racing BOSS 302 front splitter, sound-tube delete, painted plug covers, JLT oil separator. Shelby transmission scoop & powder-coated trunk brace & many more items...
IanM is offline   Reply With Quote
Old 01-27-2013, 06:01 PM   #6
bottlefed04's Avatar
Throw out bearing. Mine just started doing it.
bottlefed04 is offline   Reply With Quote
Old 01-28-2013, 08:32 AM   #7
v8pony's Avatar
TOB..mines on its way out..HATE THEM
2002 5spd GT
Feb 2013 Mustang of the Month
Old 01-28-2013, 12:27 PM   #8
cliffyk's Avatar
Check the cable first.
Unless the TOB completely self-destructed its getting noisy would not affect the clutch pedal play. Also when the cables let go they do it all of a sudden, throw-out bearings usually let you know they are not happy for weeks, even months, before they stop working...
Old 01-28-2013, 03:35 PM   #9
Kbasham5's Avatar
Just checked the cable. Couldn't find anything visibly wrong with it. While running and the cars in neutral, it will squeal off and on but as soon as I push the clutch in it starts squealing again. I was told if the squealing stopped when I pushed in the clutch it was the TOB but its completely opposite.
Old 01-28-2013, 05:32 PM   #10
cliffyk's Avatar
The inner cable can brake and there will be nothing to "see" externally...
04:49 PM
