Coolent leak help!! - Mustang Evolution
Old 01-27-2013, 02:17 PM   #1
Doe_Rae_mi's Avatar
Okay so the leak is coming from my thermostat housing..the autozone man said to replace a gasket and that will fix it..well then he said that it doesn't have a gasket?? And that I will have to buy a whole new plenum to fix this??? Is this a $200 fix or a cheap fix? If u have questions please ask them bc I need help on this. It seems to be oozing out the front but the back is squirting it out whenever I get high rpms
Old 01-27-2013, 02:22 PM   #2
98vertgt's Avatar
What year is your car?
98vertgt is offline   Reply With Quote
Old 01-27-2013, 02:53 PM   #3
Doe_Rae_mi's Avatar
There's a pic forgot to upload it but it's a 03 gt
Old 01-27-2013, 03:09 PM   #4
charlie03fastGT's Avatar
Same thing happened to me. It's the whole thing. I had to put a new manifold. The crack was on the thermostat housing by the upper radiator hose.
charlie03fastGT is offline   Reply With Quote
Old 01-27-2013, 03:17 PM   #5
Doe_Rae_mi's Avatar
U had to get a new housing?? Mines at the bottom,I'm scared if I buy the whole plenum that it's still ganna be messed up and it coulda been a simple fix and I culda just used the money for foglights
Old 01-27-2013, 03:41 PM   #6
I had to get a new intake manifold.
Old 01-27-2013, 04:15 PM   #7
Doe_Rae_mi's Avatar
I don't see a crack anywhere it's like leaking from the bottom idk. In the pic it's that little crack that's going across the whole thing. I'm about to edit a pic
Old 01-27-2013, 04:21 PM   #8
Doe_Rae_mi's Avatar
Here's where it's seeping. Also it seems to be shooting out on the backside of the housing
Old 01-27-2013, 05:27 PM   #9
cliffyk's Avatar
The inner wall of the intake manifold flange, between the thermostat housing and the head, has deteriorated allowing the formed gasket to pop out into the coolant passage--is it exactly what happened on my '03 and many other GTs as they near/pass 100k miles:
A new intake manifold is the easy fix, but NOT the Dorman manifold sold by the FLAPS--get the FRPP unit.
I ordered the FRPP replacement but got antsy and repaired mine with JB-Weld by separating the crossover and manifold, scraping it down to solid plastic, degreasing and then re-assembling with no gaskets and JB-Weld:
It has been fine for 35k miles now, and will of course never fail now that I have the new one in the attic...
Old 01-27-2013, 05:42 PM   #10
Doe_Rae_mi's Avatar
Yea I'm at 108 miles now. Oh well. Ima order the intake manifold off of American muscle. Thanks for the help guys!!
Old 01-27-2013, 05:56 PM   #11
cliffyk's Avatar
It's only $189.95 at Jegs...
Old 01-27-2013, 06:17 PM   #12
Doe_Rae_mi's Avatar
Is the shipping free though??? And is it the same thing?
Old 01-27-2013, 06:19 PM   #13
MineralGrayGT's Avatar
Region: Wyoming
Could a cracked manifold cause a hissing sound? Cause my car hisses at idle super loud but nothing at acceleration or if i rev up the motor even just a little
MineralGrayGT is offline   Reply With Quote
Old 01-27-2013, 06:21 PM   #14
Doe_Rae_mi's Avatar
Mine hisses when i first crank it but then I stops after a minute or so. Only on a cold start in the mornings.
Old 01-27-2013, 06:23 PM   #15
jjsg09's Avatar
Yes! Try spraying some throttle cleaner around the intake manifold where the hiss is coming from while the car is at idle to see if your rpms go up. If it does then yes it's probably a cracked manifold. If not check vacuum hoses.
Old 01-27-2013, 06:24 PM   #16
cliffyk's Avatar
It is the same manifold, they were $169 1-1/2 years ago. I do not know if the shipping is free, easy enough to find out...
Old 01-27-2013, 06:36 PM   #17
Doe_Rae_mi's Avatar
Lol yes.. Thank your for your help
Old 01-28-2013, 12:51 AM   #18
Mfore33's Avatar
My manifold broke at the heater core feed line at the nipple on the left rear of the manifold. Damn ford for their plastic *** intake. I bought my 2000 gt off the showroom floor for around 17500. A few hundred more for a metal intake would not have made any differance to me. But It would have saved me money later. It's an engineering failure that ford should have recalled. Greedy sobs
Old 01-28-2013, 01:44 AM   #19
cliffyk's Avatar
I agree that it's a PITA when it happens, however a $250 repair on an (in my case) 8 year-old automobile is not something one should find to be all that unusual. That works out to a whopping $31.25 per year.
Or in terms most men can understand, about 1/2 of a pony keg of Budweiser...
Old 01-28-2013, 01:16 PM   #20
Doe_Rae_mi's Avatar
How much do you think they will want for them to replace it????
Old 01-28-2013, 05:25 PM   #21
cliffyk's Avatar
I do not know, it depends on who "they" are. It is a simple task, here is the shop manual description of the procedure.
One note: You do not actually have to break the fuel line connection. Either use wire ties to fasten the injectors to the fuel rail, or "be careful" and lift the fuel rails and injectors off the manifold and place them to the side (tie them off to the side with cord if needed):
Old 01-28-2013, 05:57 PM   #22
Doe_Rae_mi's Avatar
Would $185 be to much? A guy quoted me on that today
Old 01-28-2013, 06:08 PM   #23
cliffyk's Avatar
I would not do it for any less than that. It's $50 for doing it and $135 for having the tools, space, and knowing how to do it..
Old 01-28-2013, 06:09 PM   #24
Doe_Rae_mi's Avatar
I would not do it for any less than that...
Okay thank you! I'm scared to do it myself bc ill mess something up
Old 01-28-2013, 06:29 PM   #25
Doe_Rae_mi's Avatar
Would it be okay to drive it back and forth to school? It's not like pouring out antifreeze it's just Leaking a bit. My father says it will be okay but I am scared to
Old 01-28-2013, 06:38 PM   #26
cliffyk's Avatar
I drove mine for a couple months while is was "weeping" coolant, fixed it when I got the ambition...
Old 01-28-2013, 09:50 PM   #27
etc1006's Avatar
It depends really... My stepfather has a Towncar with the 4.6 and he had a very slight weep for quite awhile, til one night he was out and it popped.... And the damn fuel pump went at the same time... THAT was weird...
etc1006 is offline   Reply With Quote
11:04 AM
