Misfire, p0156, and p0161 - Mustang Evolution
Old 01-28-2013, 06:12 PM   #1
escottcarp's Avatar
This is driving me crazy. I had the p0156 and p0161 codes and was planning to change the driver rear O2 sensor Sunday. On Saturday, I felt a misfire under a load. I changed the sensor, Sunday, and still have the misfire. The engine idles fine. I was going to let the codes disappear on their own after 50 starts. I scanned the system this afternoon and the two codes are still there and are the only codes. The scanner also showed "N/A 01/03" before giving the two codes. I checked the sensor wire as far as I could from underneath and could not find the wire from on top. I've read several online discussions and can't find a similar problem. Any ideas what to check next? I just turned 100,000 miles on my '02 GT.
escottcarp is offline   Reply With Quote
Old 01-28-2013, 09:01 PM   #2
1996mustang's Avatar
Fuse blown maybe check that first
Old 01-28-2013, 09:15 PM   #3
escottcarp's Avatar
Is there a particular fuse to check? I did happen to look at the fuses in the box near the battery and saw no blown fuses. Thanks.
Old 01-29-2013, 07:26 AM   #4
cliffyk's Avatar
P0156 indicates a problem with the passenger side rear O² sensor and has the same possible causes as P0136 (click here) . P0161 is a similar issue with the driver side rear sensor and has the same possible causes as P0135 (click here). Both are mostly power related/wiring issues.
The rear sensors have nothing to do with engine control, they just monitor the cats.
All four O² sensor heaters are powered from the same fuse, fuse #8 (20A) in the central junction box (under the dash)--as are the EGR Vacuum Regulator Solenoid, and the EVAP Canister Purge Valve and Canister Vent Solenoid.
Those could affect engine control, so check that fuse first...
Old 01-29-2013, 04:55 PM   #5
escottcarp's Avatar
Thanks. That was good info. That fuse is good and there is no corrosion around it.
Old 01-29-2013, 05:13 PM   #6
cliffyk's Avatar
The misfire would be unrelated to those codes, as I said above all the rear sensor do is monitor operation of the catalytic converters--they have nothing to do with engine control. You'll need to crawl under there and monitor the sensor output and heater voltages.
This is a wiring diagram for DIY MIL Eliminators, however it also provide the wiring colour codes for the rear sensors.
With the sensor connected there should be 12 V between the heater wires at each sensor, just after starting the engine before the exhaust heats up. Once the car is running in closed-loop mode the voltage between the signal ground and signal + should vary between 0.1V and 0.6V every 2 seconds or so.
Old 01-29-2013, 05:17 PM   #7
escottcarp's Avatar
Ok. Don't both of my codes apply to bank two and isn't bank two on the driver side? Bank one follows the #1 cylinder which is on the passenger side, yes?
Old 01-29-2013, 05:26 PM   #8
cliffyk's Avatar
Yes I got the codes mixed up previously. Both P0156 and P0161 are bank 2, sensor 2 (rear) codes.
Bank 2 is the driver side...
Old 01-30-2013, 10:24 PM   #9
escottcarp's Avatar
Concerning the misfire, the temperature is cold right now and I can count today's misfires on two fingers. Would cold weather have any impact on an engine misfiring?
Old 01-31-2013, 04:10 AM   #10
cliffyk's Avatar
It could, but it shouldn't. What engine mods do you have, if any?
Also, define "cold"? Here in NE Florida cold is 45°...
Old 01-31-2013, 05:40 AM   #11
escottcarp's Avatar
No engine mods, just a Flowmaster exhaust. Here in Jackson, MS, cold is the same as north Florida. It was in the 40's yesterday. I figure I have a coil on the blink.
04:43 PM
