13" cobra brakes?? - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1996-2004 Mustang GT
Old 01-28-2013, 11:01 PM   #1
llvllanifest's Avatar
llvllanifest is unknown around these parts
13" cobra brakes??
Has any one successfully installed front cobra brakes( calipers and all) on the rear of a gt?? I think it would look good, any thoughts
llvllanifest is offline   Reply With Quote
Old 01-28-2013, 11:04 PM   #2
Butch's Avatar
Butch is unknown around these parts
I'd put the GT fronts on the back and the Cobras in the front,, that's if the GTs will fit in the back (don't see why not but you never know)
I love speed and Nascar driving,,,
killing gears and dodging traffic,,,
-----NEHP---
{Never Enough HP}
Butch is offline   Reply With Quote
Old 01-28-2013, 11:07 PM   #3
Yeah, not a bad idea.. Just thought having cobras in the rear would look sweet plus I have not seen it done before
Old 01-28-2013, 11:10 PM   #4
BigB227's Avatar
BigB227 is unknown around these parts
I'm pretty sure with the right tools and creativity that almost anything can be done
BigB227 is offline   Reply With Quote
Old 01-29-2013, 05:38 AM   #5
lowflyn is unknown around these parts
Baer makes a 13" brake upgrade
Old 01-29-2013, 09:53 AM   #6
JDF
JDF's Avatar
JDF is unknown around these parts
How would you use your e-brake?
2000 GT-
Engine: K&N cold air intake, Bassani offroad x, Magnaflow catback, Bama 91 octane race tune, 3.55 gears dyno'd at 233whp 272wtq before exhaust
Suspension: IRS swap with stock cut 03 Cobra springs
Brakes: Front and rear brakes from an 03 Cobra with EBC Yellowstuff pads
JDF is offline   Reply With Quote
Old 01-29-2013, 12:39 PM   #7
Terminator Owner
SpectorV is just getting started.
I did this on an 01 mustang V6 (front only) was very simple. Just needed the calipers, brake pads, rotors, and brake lines.
For the rear its just a bracket and new rotors, not really worth doing out back for the most part~
Old 01-29-2013, 05:24 PM   #8
runvsofthisbull's Avatar
runvsofthisbull is unknown around these parts
I have it done on the front of mine. You can get the bullitt or Mach one brakes too as all are the same, just the 10th anniversary look prettier with the red powdercoat.
2002 True Blue V6 to GT Vert
Old 01-31-2013, 11:11 PM   #9
Yeah I agree, I'm going with the 10th anniversary calipers , rotors and lines . Like to have matching calipers all the way around
Old 02-02-2013, 06:20 PM   #10
01 stage 2's Avatar
01 stage 2 is unknown around these parts
Where can you find the 10th anniversary calipers?
01 stage 2 is offline   Reply With Quote
Old 02-02-2013, 07:34 PM   #11
Mustang_Madness is unknown around these parts
I have cobra brakes and calipers on all 4
K&N CAI, Cobra 18" Rims, Cobra Brakes, More Mods to come!
Mustang_Madness is offline   Reply With Quote
Old 02-02-2013, 11:07 PM   #12
Not sure you'll find new 10th anniversary calipers anymore but you can find cobra calipers on eBay all day long
---------- Post added at 01:07 AM ---------- Previous post was at 01:05 AM ----------
The only difference between the 10th anniversary and regular cobra calipers is that the 10th are red, buy some on eBay and powder coat em red
Old 02-02-2013, 11:07 PM   #13
Butch's Avatar
Simple swap in the rear¿ it sucks having a 13" up front and some weak looking ones in the back,,,,
-----NEHP---
{Never Enough HP}
Old 02-02-2013, 11:09 PM   #14
Yeah, it would be nice to have 13" all the way around
Old 02-03-2013, 08:00 AM   #15
01 stage 2's Avatar
I have 13" slotted and drilled rotors all the way around but I still have stock gt calipers. What do recommend for aftermarket calipers that aren't too expensive?
Old 02-03-2013, 09:19 AM   #16
Mfore33's Avatar
Mfore33 is unknown around these parts
Rock auto has the cobra brake calipers. But you need the bracket and the 13 inch rotor and pads. I recommend getting stainless steel brake lines for the front.
Old 02-03-2013, 12:32 PM   #17
JDF
JDF's Avatar
How do you have 13" rotors on the stock calipers? You would need a new bracket to fit a 13" rotor. Cobra brakes like mentioned above are a good upgrade for GTs for the money. Really anything after that is the big kits made by Brembo, Wilwood, SSBC, etc.
2000 GT-
Old 02-03-2013, 12:38 PM   #18
Venomouz831's Avatar
Venomouz831 is unknown around these parts
Yea was gonna ask the same thing how does he have 13' all around.. You pics?
)02 Gt, Founder of WE2G
Old 02-03-2013, 12:45 PM   #19
01 stage 2's Avatar
They are 13" oem rotors
---------- Post added at 02:45 PM ---------- Previous post was at 02:42 PM ----------
The stock GT calipers will fit up to 13" rotors
Old 02-03-2013, 01:12 PM   #20
JDF
JDF's Avatar
Not without a relocation bracket... stock rotor size is 11"
2000 GT-
Old 02-03-2013, 01:33 PM   #21
01 stage 2's Avatar
Well believe it or not I have 13" front and rear with my stock calipers.
Old 02-03-2013, 01:38 PM   #22
That's a first. Do you have pics?
Old 02-03-2013, 01:42 PM   #23
01 stage 2's Avatar
Yes but of the front. The car is up for the winter
Old 02-03-2013, 01:43 PM   #24
I'm looking at you're pics and the rear doesn't look like a 13'
Old 02-03-2013, 01:49 PM   #25
01 stage 2's Avatar
I haven't had a chance to put the rear ones on because of the snow.
Old 02-03-2013, 01:51 PM   #26
JDF
JDF's Avatar
Are those 18" rims? Cause a 13" rotor basically fills the gap on a 17" rim
ID:	88982   Click image for larger version
ID:	88984   Click image for larger version
2000 GT-
Old 02-03-2013, 01:52 PM   #27
01 stage 2's Avatar
No they are 20's
Old 02-03-2013, 01:54 PM   #28
13' rotor on a 18' rim...
Old 02-03-2013, 01:55 PM   #29
01 stage 2's Avatar
How much did those cobra calipers cost?
Old 02-03-2013, 01:57 PM   #30
They came on my cobra factory
Old 02-03-2013, 01:58 PM   #31
01 stage 2's Avatar
Wow! I must of gotten 11" then. Because the 20" rims I have, and with the new rotors don't take up that much of the rim
Old 02-03-2013, 03:01 PM   #32
WheelStander's Avatar
WheelStander is unknown around these parts
I am so confused
WheelStander is offline   Reply With Quote
Old 02-03-2013, 03:44 PM   #33
I agree, I don't see how 13 inch calipers are working with stock calipers. Plus stock brake pads on a gt are thicker than the cobras so I don't see how that would even work
Old 02-03-2013, 04:02 PM   #34
01 stage 2's Avatar
Like I said I got the wrong rotors. They were supposed to be 13".
Old 02-03-2013, 04:08 PM   #35
I got ya. So are you planning on upgrading to cobra calipers and rotors?
12:31 AM
