02 gt motor swap - Mustang Evolution
Old 01-30-2013, 04:20 PM   #1
Nashgizam's Avatar
Region: Nebraska
02 gt motor swap
Ok so I found a motor for 850$!!! It's outta a 2000gt and comes with an ecu will this b a straight up swap cuz I kno that's a Windsor block and I have a Romeo block
Nashgizam is offline   Reply With Quote
Old 01-30-2013, 04:24 PM   #2
I would think it would be straight forward. Should be able to use your ecm to.
Cdbformula is offline   Reply With Quote
Old 01-30-2013, 06:07 PM   #3
Nashgizam's Avatar
Region: Nebraska
U think?
Old 01-30-2013, 06:22 PM   #4
I don't think the plant where the motor is made had anything to do with it. As long as your swapping a 4.6 for a 4.6
Old 01-30-2013, 08:43 PM   #5
Nashgizam's Avatar
Region: Nebraska
That's good news than
Old 01-30-2013, 08:50 PM   #6
lee1rbc's Avatar
Use your ecu and just sell the 2000 ecu. Your security system is set for your computer, car wont start with the 2000 ecu without a reset by a tuner or factory.
2001 SVT Cobra 04 Mach 1 motor & trans, 01 Cobra cams, bassani x, flowmaster catbck, JLT CAI, 4.11 gears, Tokico D-specs, eibach springs.
lee1rbc is offline   Reply With Quote
Old 01-30-2013, 09:50 PM   #7
Nashgizam's Avatar
Region: Nebraska
So everything will work with my ecu
Old 01-31-2013, 08:20 AM   #8
Yes
Old 01-31-2013, 09:30 AM   #9
32vNomad's Avatar
If you have a romeo engine they are a 6 bolt crank setup, if you have the windsor then it has an 8 bolt crank. So you would need to change your flywheel and or flexplate depending on your new setup. as far as ecm's are concerned yours it fine and the 00 ecm is not needed.
32vNomad is offline   Reply With Quote
Old 02-08-2013, 05:23 PM   #10
Nashgizam's Avatar
Region: Nebraska
My mechanic is gonna drop in a 02 gt motor for me for 1800$ so in a few weeks we will b back on the road and I'm selling my old block to a buddy for a set of 4:10 gears
04:57 AM
