Brakes - Mustang Evolution
Old 01-31-2013, 02:22 PM   #1
Warbot's Avatar
Brakes
My front right brake seems to be sticking and making a squeaking noise when im not pressing the brakes i already regreased the slides idk what else to do. Thanks!
Warbot is offline   Reply With Quote
Old 01-31-2013, 02:24 PM   #2
Venomouz831's Avatar
Are they worn? When's the last time you changed em
)02 Gt, Founder of WE2G
Old 01-31-2013, 04:50 PM   #3
Warbot's Avatar
Well they look fine the car has 17k miles and ive had it since 10k miles and its just my front right,like its to the point sometimes when i stop i dont even roll with the clutch in and it should
---------- Post added at 04:50 PM ---------- Previous post was at 04:48 PM ----------
Its an 2004
Old 01-31-2013, 06:22 PM   #4
1slosix's Avatar
check your rubber hose...if it feels spongy or limp most likely it's colapsed
carving corners like a boss
Old 01-31-2013, 06:43 PM   #5
Mfore33's Avatar
A new caliper at rock auto .com runs from 37 to 45 bucks
A new brake hose is from 5 to 15 bucks.
If replacing the hose I suggest replace both fronts since they have same wear on them. Got to bleed lines anyway. The caliper guide pins need grease when changing pads. Sometime they can rust and get sticky causing caliper to stick.
Old 01-31-2013, 06:45 PM   #6
1slosix's Avatar
if you have to replace any brake line consider just buying a SS set...best thing i've done for my braking besides good pads
Old 01-31-2013, 08:21 PM   #7
BigB227's Avatar
+111 I had the same issue and replaced the calipers, rotors, pads and all an no squeak. I got everything from rock auto
BigB227 is offline   Reply With Quote
Old 01-31-2013, 08:27 PM   #8
Warbot's Avatar
Caliper guide pins? Are those the ones on the black bracket around the caliper? Their sealed?
Old 01-31-2013, 08:33 PM   #9
Warbot's Avatar
And im guessing its the caliper the hoses look fine just 8 years of sitting in a garage till i bought it probably wasnt good for the pucks haha
Old 02-01-2013, 03:19 AM   #10
Mfore33's Avatar
Google a pic for the caliper guide pin. They have a rubber boot that covers them.
Old 02-01-2013, 11:40 AM   #11
Warbot's Avatar
Ohhh yeah thats what i greased its fine think just the caliper isnt letting off and my brake fluids fine.
01:01 PM
