Vortec? Or kenne bell?? - Mustang Evolution
Old 01-31-2013, 10:48 PM   #1
Jord05's Avatar
So I decided to go with a super charger but not sure which one. My engine is new but mostly stock besides some bolt ons. I wanna get cams for my car as well at the same time what would be the best set up for a mean idle with the cams and a nice whine for supercharger. Also how high of boost can I run with this set up on stock everything else.
Jord05 is offline   Reply With Quote
Old 01-31-2013, 10:50 PM   #2
1lowGT's Avatar
Anything forged? The block can handle 400-50hp
Old 01-31-2013, 10:56 PM   #3
Jord05's Avatar
Nope block is stock for now so I want the cheapest way to do it for now and not worry about ****ing my girl up hahah. Best websites and links would be appreciated would like to get her running by summer! Thanks
Old 01-31-2013, 11:00 PM   #4
1lowGT's Avatar
I wouldn't push your block to far boost I would say 7-10
American muscle. Late model restoration. Cj pony parts. Summit racing.
Old 01-31-2013, 11:00 PM   #5
The block can hold up to that much power, but if it is a DD you don't want to go past 350
Old 01-31-2013, 11:03 PM   #6
Jord05's Avatar
Ok and what about cams? Are they worth it?
Old 02-01-2013, 04:45 AM   #7
WheelStander's Avatar
The block can handle way more than that.
Like 700.
It's the internals and heads that top out at 450 rwhp.
Induction: Kenne Bell | wHp: 515 Tq: 503 | 1/4 Mile:11.09@123
WheelStander is offline   Reply With Quote
Old 02-01-2013, 11:08 AM   #8
nickysixx's Avatar
Like 700.
Yep, the blocks are rated for 650-700 HP. It's more so your internals (rods - pistons - rings - ect. ) I'd be worried about. Stock compression ratio is like 9.4:1 isnt it that year? So he can probably safely run like 12 PSI on stock.
nickysixx is offline   Reply With Quote
Old 02-01-2013, 11:53 AM   #9
Agreed, with the proper tune.
Old 02-01-2013, 11:54 AM   #10
Jord05's Avatar
Ok so it would be safe to run 8psi with aftermarket cams?
Old 02-01-2013, 11:55 AM   #11
Depends on the cams.
Old 02-01-2013, 11:59 AM   #12
Jord05's Avatar
What would you recommend ? And we're from?
Old 02-01-2013, 12:29 PM   #13
nickysixx's Avatar
Well if your going with mild cams, I wouldn't even do anything crazy. Just get proper cams for a boosted gt. stage 1 if they have them. Run 8 PSI, It's going to be a lot for a little.
Old 02-01-2013, 12:34 PM   #14
Skip the cams no point your build.
Just go sc until you are ready to build heads and bottom end.
Or do that first.
Old 02-01-2013, 12:47 PM   #15
nickysixx's Avatar
Or do that first.
Well Agreed, It's not really worth it. Unless your building internals your not going to get the Horsepower to $$ ratio. Get a charger, Kennebell is my personal prefrence, and get your car tuned properly. Car will be awesome.
Old 02-01-2013, 12:55 PM   #16
Agree
11:15 PM
