Kenne Bell - Mustang Evolution
Old 07-09-2008, 04:12 PM   #1
oaktonarcher's Avatar
Send a message via AIM to oaktonarcher
Kenne Bell
What do you all think of a kenne bell 2.1 with 9 psi on a stocker 04 GT with like 25k on it?
it sounds like a blast to me, and not toooo much strain on the engine but i dont really know. any thoughts?
is this a fabulous way to blow up a 2v 4.6?
im mainly guessing that it would be fun/ not to terrible for the engine with a good tune on it. i just remember really wanting a root style blower back when someone was making a kit for the 99-04 V6 cars to put an Eatons M-90 on them.
Delta Sigma Phi
building better men since 1899
You still have a quote in your sig from a guy that hasn't signed in in almost 2 years
www.DeltaArmsCo.com
oaktonarcher is offline   Reply With Quote
Old 07-09-2008, 04:15 PM   #2
Send a message via AIM to black98gtvert
Re: Kenne Bell
it would be a great blower. the kenne bell also has that specific whine to it. but if you do that your gonna have traction problems if you dont mod your suspension and get some good tires... 400hp can hook up on regular old 245 tires just throwing out some advice
98 GT Vert
Mods: MAC CAI,FLOWS 40 series,MSD Wires and Coils,"MM"starter box susp, MAC underdrive pullies, BBK off-road X, Steeda TRI-Ax, 3.73 gears, Sniper Special Forces Tuner, Accufab 75mm TB and Plenum, and a ZEX __ Shot
04 CBR F4i: A Street Machine on roids
black98gtvert is offline   Reply With Quote
Old 07-09-2008, 05:51 PM   #3
Thomas91169's Avatar
Re: Kenne Bell
Shouldnt be too bad. Dunno if those are aftercooled/intercooled, might be something to look into.
The problem with roots/twin-screw blowers is the stress they put on the rotating assembly at the bottom end of the rpm range where the load placed on the motor is greatest.
Also it would be a M112 Eaton FYI. A M90 is from the tbird SC and is way too small to be of any use on a 4.6L. Hell even the M112 is barely efficient enough past 15psi to do anything more than blow heat.
I think as long as you treat the car fine with the 2.1L and dont overly abuse it, have a safe tune and support, you will be good to go.
-Thomas-
Old 07-10-2008, 07:22 AM   #4
Re: Kenne Bell
the 99-04 gts can handle about 450rwhp (I wouldnt personally push them above 400rwhp) and if the tune is right and its not beat on~ it should be ok... but its just one of those chances you have to take. If its around 20k I wouldnt touch it (i doubt its that much) cuz thats 03 cobra territory.
Old 07-10-2008, 10:18 AM   #5
Re: Kenne Bell
o sorry what i meant by 20k was the mileage on the car. im thinking with nice exhaust and a 9 psi set up, ill be right around 400 whp.
Delta Sigma Phi
www.DeltaArmsCo.com
Old 07-10-2008, 10:26 AM   #6
Re: Kenne Bell
itll be fine, watched a guy dyno one recently and he made just over 400hp. not sure on the pulley size but i know it wasent super small.
SimplyOrange is offline   Reply With Quote
Procharger or Kenne Bell? MonteCitan 1996-2004 Mustang GT 15 11-08-2009 12:42 PM
Kenne Bell GT500 Edition bluemustang General Car Discussion 40 03-10-2007 02:32 PM
12:41 AM
