3rd gear grinding - Mustang Evolution
Old 02-01-2013, 12:07 PM   #1
Kstangs2002's Avatar
3rd gear grinding
I think its a synchronizer is this expensive to fix i could still put in 3rd just i have to put it in slowly FML
Kstangs2002 is offline   Reply With Quote
Old 02-01-2013, 08:29 PM   #2
runvsofthisbull's Avatar
Mine almost always grinds going into 2nd especially until the car gets to normal operating temperatures. Perhaps put some new synchromesh in it...Amsoil or RP fluid may help.
2002 True Blue V6 to GT Vert
16.1@86 as an auto 3.8
Old 02-01-2013, 09:02 PM   #3
nickysixx's Avatar
What exactly is it doing? Usually some fluid does it good. Probably will be able to shift normal just not going to be able to bang through gears
____________________________________________
1957 Buick Special Estate Wagon
1996 Mustang GT (sold)
1997 Mustang V6 (sold)
2002 Jeep Grand Cherokee Laredo (sold)
2007 Jeep Grand Cherokee
nickysixx is offline   Reply With Quote
Old 02-01-2013, 09:12 PM   #4
If im a shift from second to third normally it grinds pretty bad that it wont go in unless i force it in or if from second to third but shift it in slowly it will go in with not much grind
Old 02-01-2013, 09:27 PM   #5
nickysixx's Avatar
Definitely do a fluid change before it gets worse.
Old 02-02-2013, 03:39 PM   #6
Speed_Mister's Avatar
Region: Arkansas
If you want it fixed unbolt the tranny drop it and give it to a transmission shop to fix it. It won't cost much maybe 600$ to fix for parts and labor
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 02-02-2013, 03:49 PM   #7
schmitty426's Avatar
Its definitely a Synchronizer same thing happened to me... Sooner or later your not going to have a gear at all, I'd drop the tranny yourself and bring it to a shop
schmitty426 is offline   Reply With Quote
Old 02-02-2013, 03:52 PM   #8
Region: Arkansas
Yep that happened to me grinding got so annoying I took it to the shop raced it that weekend before fixing it and my 3rd and 4th gear the two gears that were grinding seemed like nothing was there. Apparently a pin that held the shift fork came out and was just floating around in my tranny.
Full Bolt Ons
370rwhp 470rwtq
Old 02-02-2013, 04:07 PM   #9
Yeah I had it so bad to where I could go into third easier then b4 it busted and it were as if I was in neutral lol I'd drove with it for like a week I'd mash it 1st thru 2nd and skip to 4th.. super annoying! Dealership showed me the trannys internals and I coulda added some milk and have myself a bowl of synchros lmao
08:20 AM
