Pi swap - Mustang Evolution
Old 02-01-2013, 09:50 PM   #1
Fordhartbreaker's Avatar
Pi swap
Ik this may of been asked before but what is needed for the pi swap I have a 96 gt if u can forward me a good list or something that would be cool thanks guys sry been gone a while
Fordhartbreaker is offline   Reply With Quote
Old 02-02-2013, 03:56 PM   #2
jdavis96gt's Avatar
Region: West Virgina
On eBay they have kits already made up. Water nipple, alt bracket, water hose for n the valley, gaskets, o rings for injectors.
Old 02-02-2013, 06:03 PM   #3
nickysixx's Avatar
+1 but not just eBay. Quite a few mustang outlets are realizing this is a huge common swap for the 96'ers.
____________________________________________
1957 Buick Special Estate Wagon
1996 Mustang GT (sold)
1997 Mustang V6 (sold)
2002 Jeep Grand Cherokee Laredo (sold)
2007 Jeep Grand Cherokee
nickysixx is offline   Reply With Quote
Old 02-02-2013, 07:08 PM   #4
Sweet thanks guys and does it really add around 30hp?
Old 02-02-2013, 07:20 PM   #5
nickysixx's Avatar
Known to add approx 40 flywheel hp. It's the only difference between 96-98 to 99-04 beside comp ratio
Old 02-02-2013, 07:30 PM   #6
Awesome I'm mechanically inclined to an extent is this a hard task?
Old 02-02-2013, 07:32 PM   #7
Mustang_Madness's Avatar
I dont want to jack this thread so only one question. When i get pi heads and intake, as well as gaskets an all, i can just put them in, and call it good? Do i Need to tune it? I dont want to spend alot of money, and i just need to change the headgaskets, but im inclined to do a pi swap while in there...
K&N CAI, Cobra 18" Rims, Cobra Brakes, More Mods to come!
Mustang_Madness is offline   Reply With Quote
Old 02-02-2013, 07:40 PM   #8
nickysixx's Avatar
You shouldn't need to unless your doing a more major mod while doing it. I would always recommend a tune anyways. It will maximize your performance gain. A pi swap is a lot more than a change if a gasket while your there. Like said before they sell pre made up kits to help you a long the way of doing your pi swap.
Old 02-02-2013, 08:01 PM   #9
On eBay?
Old 02-02-2013, 08:14 PM   #10
nickysixx's Avatar
On eBay?
Yep, and I believe a few vendors are selling them now.
Old 02-02-2013, 08:25 PM   #11
jdavis96gt's Avatar
There's 45hp difference between npi and pi. Plus the compression bump, your looking at 50-55hp. You'd be around 270 to flywheel, not including other mods.
Bama wont tune for pi swap, just intake swap. So you'll have to get custom tune. I don't think u need a tune but they always help.
Old 02-02-2013, 08:32 PM   #12
jdavis96gt's Avatar
Npi-215hp
Pi-260hp
You'll also have to run 93 gas.
Old 02-02-2013, 09:02 PM   #13
Ok so just the intake manifold, would this alone be a decent improvement?
Old 02-02-2013, 09:05 PM   #14
nickysixx's Avatar
I believe manifold alone gets like 15 hp gain. Not much
Old 02-02-2013, 09:07 PM   #15
Not much but would be a start with other bolt ons and programer
Old 02-02-2013, 09:17 PM   #16
ty98gt's Avatar
Npi-215hp
Pi-260hp
Im thinking about doing a PI swap for my 98gt as well. Is it possible to run 91 octane with the swap? They don't sell 93 in my area..
Engine/drivetrain mods: Pro 5.0 Short Shifter, Dragon Plenum-75mm, Accufab TB-70MM, K&N FIPK GEN.2 Air Intake, Bassani Cat Back Exhaust,Bassani Catted X Pipe, 3.73 FRPP Rear Gears,Ford Racing TA Rear Diff Cover,
Bunch of suspension goodies
ty98gt is offline   Reply With Quote
Old 02-02-2013, 09:25 PM   #17
jdavis96gt's Avatar
I don't know on that. I can only get 92. You could just do came and intake.
Intake swap is good for 15whp. Bama will tune for that. So both together would make a nice difference.
Old 02-02-2013, 09:43 PM   #18
ty98gt's Avatar
Im gonna look more into this, what is the price range on the pi intake?
Old 02-02-2013, 09:47 PM   #19
jdavis96gt's Avatar
Used 50-100, new 200. But there's little stuff u need. Google pi intake kit.
Old 02-02-2013, 09:50 PM   #20
ty98gt's Avatar
Will do, thanks for the info!
Old 02-03-2013, 06:50 AM   #21
1996mustang's Avatar
You dont need a tune when u upgrade to pi heads. Its basically a head gasket replacement that adds on 55hp roughly and compression is bumped to 10.54:1. 93 octane is recommended due to the higher compression.....however ive been on 87 for the past 5yrs on mine and ive been ok. But its not something im saying that its ok to run lower octane. 91 octane should do fine if u dont have 92 or 93 octane. Also if ur mechanically inclined its a pretty straight foward job only tricky part to any stang is getting the timing on point. Other than that is it worth it? Imo yes u notice the difference right away and any mods u put u can feel. My suggestions is have the heads ported and springs upgraded for future growth first. Saves u time and money down the road and ported heads flow more so add on a 15 to 20 roughly more on top to swap
and like i said imo
Old 02-03-2013, 08:12 PM   #22
and like i said imo
Awesome info man thanks a lot
06:33 AM
