96 gt motor swap into my 02 gt - Mustang Evolution
Old 02-02-2013, 04:46 PM   #1
mustang2323's Avatar
Good idea or bad? What all will I need to change, I'll be putting my heads and intake on to make it PI. To make the compression 10:1. But the motor from the 96 is in an automatic gt does it matter with my manual tranny? Will it still bold right up (the crank to the cam shaft)
mustang2323 is offline   Reply With Quote
Old 02-02-2013, 05:05 PM   #2
I meant the crank to the flywheel. Will the automatic 96 bolt up to my manual 02
Old 02-02-2013, 07:01 PM   #3
nickysixx's Avatar
Would work, by all means not a bad idea. If your doing the pi swap you might end up with a bit more horsepower than you previously hard. What other upgrades would you throw into the mix?
____________________________________________
1957 Buick Special Estate Wagon
1996 Mustang GT (sold)
1997 Mustang V6 (sold)
2002 Jeep Grand Cherokee Laredo (sold)
2007 Jeep Grand Cherokee
nickysixx is offline   Reply With Quote
Old 02-02-2013, 07:12 PM   #4
Well I have 373 gears, I don't know what all I wanna do yet. I'm sure the upgrades are about the same for the two motors but not sure what all I wanna do. But your for sure that the swap will work? Im going to use the coil packs off of the 02 motor as well, just so I don't have the two coil packs and wires to worry about.
Old 02-02-2013, 07:42 PM   #5
nickysixx's Avatar
most of them are the same. I mean virtually will be all the same if your keeping the PI Heads. It will ALL be the for the motor its self. I have a teksid block I need to put together yet with terminator heads. It'll be a interesting project as well. But let me know if you have anyquestions as far as the build. I did the infomous PI Swap twice so its pretty easy now. I'll be happy to help when ever I can. Also, As far as the bolt up on the trans it should be fine. A couple of people I know did auto to manual conversions on there sn95's. there housing is the same
Old 02-02-2013, 07:50 PM   #6
Could you call and talk more about this I could really use as much help as I can get on this just so I know what I'm getting into. Call ASAP. 812 582 1542
Old 02-02-2013, 08:30 PM   #7
nickysixx's Avatar
Good luck! Hope I gave you good insight
08:27 PM
