Broken OIL PUMP - Mustang Evolution
Old 07-10-2008, 03:37 PM   #1
67mustang97's Avatar
Region: Vermont
Broken OIL PUMP
I recently had a oil pump failure on the intestate resulting in a blown engine. Is this a common problem? my car is a 02 GT with just 29K, If I decide to put another engine from ford in it should I upgrade the oil pump before installing?
Old 07-10-2008, 07:31 PM   #2
Scut95's Avatar
Re: Broken OIL PUMP
That is just a freak thing that happened.....oil pumps don't go bad too often...if you want to upgrade the pump you can but it's not necessary
Old 07-11-2008, 03:24 PM   #3
1234's Avatar
Re: Broken OIL PUMP
Never heard of it happening. Its a gear driven unit directly off of the crank. Not to many pieces that can go bad.
Old 07-11-2008, 03:33 PM   #4
Region: Vermont
Re: Broken OIL PUMP
The gear broke off. I heard if you modify a 4.6 a little to much this will happen. I wish I heard this before I started, A new pump is a lot cheaper than the 6 grand the dealership quoted me for a long block!
Old 07-11-2008, 03:43 PM   #5
1234's Avatar
Re: Broken OIL PUMP
This is true.
Old 07-11-2008, 03:52 PM   #6
Region: Vermont
Re: Broken OIL PUMP
I have heard of people putting in Cobra oil pumps to prevent broken gears. They are supposed to be made with better materials. Looking back I don't think I made enough power to have this problem. I only had 302 crank hp and 355 lbs of torque, maybe mine was just plain weak. For all of you on here with big hp numbers you may want to look into this so your car doesn't suffer from the same fate mine did.
Oil pump screen help mmmchia Pre-2005 V6 Mustang 1 09-08-2009 11:29 AM
WTB: Electric Air Pump (smog pump) MagnuM Mustang Parts for Sale and Wanted 0 05-16-2007 10:10 AM
500RWHP Broken GT-Eater Pre-2005 V6 Mustang 47 03-25-2005 09:43 AM
F'ing A, got broken into Thomas91169 The Bar 22 08-22-2004 08:49 PM
10:40 AM
