02-04-2013, 02:30 PM
#1 | | Registered User
| Heads ?
Can the heads on a 99-04 2v be removed while the engine is in the engine bay?
02-04-2013, 02:33 PM
#2 | | Registered User
Yes
02-04-2013, 02:58 PM
#3 | | Registered User
Do u knw if its a pain to do?
02-04-2013, 03:20 PM
#4 | | Registered User
It takes a lot of time and a lot of work
02-04-2013, 03:22 PM
#5 | | Registered User
| Quote:
Originally Posted by 2300turboford It takes a lot of time and a lot of work | I removed the 5,4 3v heads off of a f150 whole the engine was in the bay...I'm sure this would be easier  . Like he said it takes time...it's not a 2 hour procedure. And you will want to get new gaskets and head bolts
2001 Ranger Edge 4x4 xcab (sold to cousin) 4.10 Gear/RPM thread |
#6 | | Registered User
Yea a shop said takes 10 hours but I was also asking for them to be ported and polished
__________________  )02 Gt, Founder of WE2G
02-04-2013, 04:20 PM
#7 | | Registered User
| Quote:
Originally Posted by Venomouz831 Yea a shop said takes 10 hours but I was also asking for them to be ported and polished | Port and polish? Are you aware of the plus and minus and full scenario of it? Do you daily drive the car? Do you drive it far?
____________________________________________
1957 Buick Special Estate Wagon
1996 Mustang GT
2002 Jeep Grand Cherokee Laredo
02-04-2013, 04:23 PM
#8 | | Registered User
Yea I am. I drive it about 5-10 miles a day and its my track, autox, and drag car
02-04-2013, 04:25 PM
#9 | | Registered User
| Quote:
Originally Posted by Venomouz831 Yea I am. I drive it about 5-10 miles a day and its my track, autox, and drag car | So you daily drive the car you autocross and drag?
1996 Mustang GT
02-04-2013, 04:26 PM
#10 | | Registered User
Yeap check out my vids! I just got my cobra so it will need some suspension work
02-04-2013, 04:30 PM
#11 | | Registered User
| Quote:
Originally Posted by Venomouz831 Yeap check out my vids! I just got my cobra so it will need some suspension work | If you drive the car 5-10 Miles a day, Porting and polishing isn't a good idea... I'd recommend a SLIGHT Port with a Mild Polish... Better combustion and better gas milage and it's not nearly has harsh on your motor. I used to be all for it but after I started doing some research and testing the waters with the port and polish theory. If you want some techy information I will happily PM you a decent amount of research I have spent time doing in the past two years on porting and polishing.
02-04-2013, 05:51 PM
#12 | | Registered User
| Quote:
Originally Posted by nickysixx If you drive the car 5-10 Miles a day, Porting and polishing isn't a good idea... I'd recommend a SLIGHT Port with a Mild Polish... Better combustion and better gas milage and it's not nearly has harsh on your motor. I used to be all for it but after I started doing some research and testing the waters with the port and polish theory. If you want some techy information I will happily PM you a decent amount of research I have spent time doing in the past two years on porting and polishing. | im interested pm me on the research, got a set of pi heads laying around extra to do all i want to them first before i install.
02-04-2013, 07:17 PM
#13 | | Registered User
| Quote:
If you drive the car 5-10 Miles a day, Porting and polishing isn't a good idea... I'd recommend a SLIGHT Port with a Mild Polish... Better combustion and better gas milage and it's not nearly has harsh on your motor. I used to be all for it but after I started doing some research and testing the waters with the port and polish theory. If you want some techy information I will happily PM you a decent amount of research I have spent time doing in the past two years on porting and polishing. | I'd like Ty info too..
02-04-2013, 07:32 PM
#14 | | Registered User
I'll send it to you both when I boot up my pc in a bit.
1996 Mustang GT
02-04-2013, 08:54 PM
#15 | | Registered User
sent you both a PM, that was just a quick summary of what my notes are. there really like 5 pages long going into measurements and blah boring stuff.
1996 Mustang GT
02-05-2013, 08:22 PM
#16 | | Registered User
Wanna send that my way too??
02-06-2013, 08:24 AM
#17 | | Registered User
So if I did a trick flow head swap on my car that gets driven a bit its not a good idea? I plan to get another car so I can garage my Stang and drive it only in nice weather. I like the number gains from the trick flow heads.
02-06-2013, 09:31 AM
#18 | | Registered User
A good portion of those numbers though are due to the cams I believe. Don't get me wrong I think their heads are sweet and if I had 2gs laying around I'd put them on. I'd probably go all out and get the heads, cams, and bullit-style intake while I'm at it. Car would be a whole new animal. I dont think that their heads would cause your car any issues. Yes porting and polishing removes material and can lead to engine issues, but I doubt TF would be in business if you couldn't use their heads for an extended period of time without risking engine failure etc etc.
2002 True Blue V6 to GT Vert
02-06-2013, 11:05 AM
#19 | | Registered User
| Quote:
Originally Posted by runvsofthisbull A good portion of those numbers though are due to the cams I believe. Don't get me wrong I think their heads are sweet and if I had 2gs laying around I'd put them on. I'd probably go all out and get the heads, cams, and bullit-style intake while I'm at it. Car would be a whole new animal. I dont think that their heads would cause your car any issues. Yes porting and polishing removes material and can lead to engine issues, but I doubt TF would be in business if you couldn't use their heads for an extended period of time without risking engine failure etc etc. | Correct, I'm talking in regards too having your heads Port and Polished. I'm personally not a fan of trick flow heads.
1996 Mustang GT
