94-04 k member help??? - Mustang Evolution
Old 02-04-2013, 07:14 PM   #1
asraistar's Avatar
Hello does anyone know if the k member is the same from 94-04? Reason i ask is i know alot between those years is interchangeable. My car 2000 has a bad k member but i can get one from a 94 cheap. Thank you
asraistar is offline   Reply With Quote
Old 02-04-2013, 08:47 PM   #2
runvsofthisbull's Avatar
I'm not sure but are the motor mounts in a diff position considering the 5.0 was the power plant and not a 4.6? I'd just line it up next to yous and make some measurements. But if it looks different you can get a used one off eBay for like 100-150 for the correct year or go with a tubular one for a little more money/wt reduction.
2002 True Blue V6 to GT Vert
16.1@86 as an auto 3.8
Old 02-04-2013, 09:01 PM   #3
asraistar's Avatar
Ya that would work too but a parts car is always good lol. But thank you
Old 02-05-2013, 11:58 AM   #4
I know that you can basically use any 94-04 A arms with a 99-04 K member (the bushings are slightly different sizes according to MM), however I'm pretty sure that the motor mounts are in fact different. Now if the mounts themselves are the only difference you could swap out yours and put them on the K member, but if it is the motor mount towers that are different I'd think you'd be better off just getting a 99-04 K member that way you know it fits.
06:03 PM
