Chirping Sound with New Rim - Mustang Evolution
Old 02-04-2013, 07:16 PM   #1
Schnurminator's Avatar
I replaced a rim recently for my drivers side rear tire and when I'm driving I hear a chirping sound coming from that area. Any ideas on what's wrong and how to fix it?
Schnurminator is offline   Reply With Quote
Old 02-04-2013, 07:33 PM   #2
nickysixx's Avatar
Sounds like a wheel bearing.
____________________________________________
1957 Buick Special Estate Wagon
1996 Mustang GT (sold)
1997 Mustang V6 (sold)
2002 Jeep Grand Cherokee Laredo (sold)
2007 Jeep Grand Cherokee
nickysixx is offline   Reply With Quote
Old 02-04-2013, 08:07 PM   #3
deadsp0t's Avatar
Does the sound speed up with the car? Does it stay the same no matter how fast you go? Do brakes or clutch affect the sound...?
Answers are found in details.
That's unimpressive
Old 02-04-2013, 08:13 PM   #4
Ubnbit's Avatar
Without more detail, I know the rear has an automatic adjuster for e-brake. I had a Taurus once that the adjuster was all the way out and chirped. It continued to get worse until it was a whistle or squeal. Could be something more simple. Could be build up of dust. Take the tire off and check it out. I'd give you my brake cleaner if you were close.
---------- Post added at 10:13 PM ---------- Previous post was at 10:11 PM ----------
Have you ever changed the rears?
Old 02-04-2013, 09:10 PM   #5
It speeds up as I do and when I brake it goes away. So I'm maybe thinking rubbing on the caliper?
Old 02-04-2013, 09:12 PM   #6
Ubnbit's Avatar
Just get some brake cleaner. Take off the tire and clean it all good. If it still does it, you'll know to go deeper.
Old 02-04-2013, 09:13 PM   #7
I just bought the car in early December and I got into an accident where the rim cracked so I bought a new one and had Wal-Mart switch out the rims and ever since then it's chirped
---------- Post added at 10:13 PM ---------- Previous post was at 10:13 PM ----------
Ok I'll try that. Thanks!
Old 02-04-2013, 09:23 PM   #8
Ubnbit's Avatar
Once you get the wheel off, you will be able to tell a lot.
Old 02-04-2013, 10:21 PM   #9
BigB227's Avatar
I got into an accident where my rim got a bit bent and my car made a squeaking noise in the rear where it got hit. It ended up being the caliper. The impact bent the caliper piston so I had to replace it and all
BigB227 is offline   Reply With Quote
Old 02-04-2013, 11:00 PM   #10
Tyoung68's Avatar
Hows your alignment?
Old 02-04-2013, 11:32 PM   #11
Voltage258's Avatar
Region: Utah
Does it sound like this.? Sound starts like 46 seconds in or so..... If so multiple people have had this problem. This is my car and I have not fixed it yet but 3 people had the exact same sound and they replaced their rear caliper and then it went away.....
If your getting good gas mileage, your not having fun.
Voltage258 is offline   Reply With Quote
Old 02-05-2013, 12:15 AM   #12
EthanGT03's Avatar
Same problem here. Had it since my wreck. Looks like the caliper might be next to replace .(
EthanGT03 is offline   Reply With Quote
Old 02-05-2013, 08:54 AM   #13
I'll check out the caliper. Thanks!
Old 02-05-2013, 09:50 AM   #14
Voltage258's Avatar
Region: Utah
No problem. Let us know if it works.
10:33 AM
