Control Arms Help?? - Mustang Evolution
Old 02-06-2013, 05:52 PM   #1
98StangKid's Avatar
Control Arms Help??
Hey guys, my new set of Upper and Lower Control arms came in today. My dad was going to help me, but he got called to work early. How hard is the install? I'm somewhat Mechanically inclined. Could me and a friend do it?
'01 Cobra
Forged Internals, Limited Slip Differential, 3:73s, Bama Tune, Pro 5.0 Short Shifter, Mach 1 Air Intake, 31 Spline Moser Axles.
98StangKid is offline   Reply With Quote
Old 02-06-2013, 09:04 PM   #2
Ewokjax95's Avatar
You and your friend should be able to do it for sure. I'm think they're almost identical, but on my sn95, it took maybe an hour just to access both by myself. I didn't swap them but I did take them out with no problem.
Ewokjax95 is offline   Reply With Quote
Old 02-06-2013, 09:18 PM   #3
98StangKid's Avatar
Ok. Cool. Did you have to take out your gas tank?
'01 Cobra
Old 02-06-2013, 10:36 PM   #4
Krazy Horse's Avatar
You do not have to drop the gas tank, just make sure you use jack stands and have it up high enough to get under at least to reach the upper inside bolts. Pull rear sway bar off completely to put back on last. Take shocks loose both sides, then support rear end and should not have any problems
Krazy Horse is offline   Reply With Quote
03:37 AM
