Sub - Mustang Evolution
Old 02-07-2013, 08:27 AM   #1
R6man's Avatar
Sub
I got thw mach speaker system.i have a 12 sub. Can I hook this up to stock amps
R6man is offline   Reply With Quote
Old 02-07-2013, 09:51 AM   #2
To power it? No...
Old 02-07-2013, 01:21 PM   #3
98vertgt's Avatar
You'll need a new amp for it. I have a 12 and it has its own amp powering it.
98vertgt is offline   Reply With Quote
Old 02-07-2013, 02:40 PM   #4
Mfore33's Avatar
Get a infinity bass link system
Old 02-07-2013, 02:54 PM   #5
R6man's Avatar
I need a new radio then to?
Old 02-07-2013, 02:56 PM   #6
98vertgt's Avatar
Yep
Old 02-07-2013, 02:58 PM   #7
R6man's Avatar
Screw that rather spend money om mods
Old 02-07-2013, 03:49 PM   #8
Mfore33's Avatar
No you can still hook that up to a factory radio. You can splice in a RCA converter into the rear outputs
Old 02-13-2013, 08:20 PM   #9
R6man's Avatar
Which wires do I splice into and how do u get radio out
Old 02-13-2013, 10:20 PM   #10
02PONY's Avatar
Go to mustangworld.com. There's a write up on how to add an extra amp/subwoofer to the Mach stereo system. I used this write up and mine sounded fine
02PONY is offline   Reply With Quote
Old 02-14-2013, 12:28 PM   #11
R6man's Avatar
Where u buy that converter
Old 02-14-2013, 01:24 PM   #12
Mfore33's Avatar
Go to scoche.com I got mine from Walmart.
Old 02-17-2013, 12:19 AM   #13
02mineralgreygt's Avatar
All I did was find a wiring diagram of the amps and tap into the wires for the front 6x8. I dont know how long those factory amps will work with your 12 but they did fine for me until I got enough money for the rest of the system. ( I did have those front 6x8 disconnected when I had that set up)
02mineralgreygt is offline   Reply With Quote
Old 02-17-2013, 08:22 AM   #14
R6man's Avatar
Im gonna use that converter. I found the plug between the amps that I need to slpice.. Now I just gotta do it..****
11:33 AM
