1999 Mustang V6 to 308 Carb swap - Mustang Evolution
Old 02-08-2013, 12:03 AM   #1
99GreenStang's Avatar
lright I'd like to start off by saying HELLO! I'm brand new to the forum although have alot of knowledge as im sure all of you do about mustangs . I personally do not like Electronic Fuel Injection or the V6 but did not want to sell the car and do what most people suggest of buying a GT wheres the experience in that ! So I looked around and found a 302 block that was in good shape and started a little research , this question gets asked more than any question in the world LOL " Can you really put a 302 Carb in a 99-04 " Of course ! With enough duct tape and welding anythins possible LOL JK . After waiting for the motor and crank to come back from the machine shop , I redid the heads myself and awaited it to do the rebuild myself . Got the motor back rebuilt it . Bored 40 over makes it a 308 most proble know this same bore size as a 350 chevy . Sticking with the 4r70w transmission and Stock V6 K member . ( YES I SAID I DID NOT CHANGE K MEMBER ) You can use 89 Foxbody GT mounts or you can take 94-95 GT mounts and turn the passenger side one around backwards ( take keeper out drill hole through and put bolt and nut to secure ) falls right into place.. After fitting motor in basic assembly started and of course I am going carbed you can actually see a change rather than doing a tune that you cannot see any change ? I would rather turn a screw and know something actually happened than just trust electronics ( JMO ) Carbs will and can run just as good if not better than EFI and cheaper . After getting all this done I of course done my own head work and got a set of GT40P heads ( SUMMIT SELLS P HEADERS FOR 95 FITS CHASSIS PERFECT) put in double springs and hardened seals and full roller rockers . For the Fuel system I made a fuel cell frame and cut the spare tire well out and mounted a new 15 gallon fuel cell very clean looking ! . Ran Return System 8AN steel braided into a Holley Blue pump into a Mallory 4309 Regulator . For ignition I am using a MSD 6AL with pro billet dizzy and blaster 2 and msd wires *(Also on ignition for the starter there is one wire that is hot while cranking over engine have to find it on big plug under hood and splice into and run a relay to starter) . Starter i am running a Mini starter ( you can use stock v6 one theres no difference ) and to turn fan on am using a fan relay controller that is adjustable . For the pulleys easiest route is a march performance kit i removed all AC LINES AND STOCK FUEL LINES ( NEED special disconnect tool 10 bucks ) also polished billet alluminum looks great ! but comes with a price lol .
ID:	89750   Click image for larger version
ID:	89752   Click image for larger version
ID:	89754   Click image for larger version
ID:	89756   Click image for larger version
99GreenStang is offline   Reply With Quote
Old 02-08-2013, 12:07 AM   #2
---------- Post added at 01:07 AM ---------- Previous post was at 01:06 AM ----------
Check out the video link i posted above the engine looks alot better currently am awaiting a trans controller and cleaning up wiring . Please comment thanks .
Old 02-08-2013, 12:36 AM   #3
http://m.youtube.com/#/watch?v=5OnAU...e_gdata_player
Old 02-08-2013, 08:45 AM   #4
runvsofthisbull's Avatar
Welcome to the site. Its definitely a different animal now. What do you plan on running for exhaust besides headers? Also what do you have planned for monitoring you mustang (gauges?). I like it. You may actually get more feedback from the guys in the 79-93 forums though since you went with a carborated pushrod style motor. What rear-end are you running also? You know the stock V6 is only a 7.5 inch correct? I know it can handle some power (300rwhp), but beyond that you may be pushing its limits. Well done though!
2002 True Blue V6 to GT Vert
16.1@86 as an auto 3.8
Old 02-08-2013, 09:33 AM   #5
Thank u ! I have got 3' stainless steel exhaust no cats all the way back running into some flow masters just gotta get it hooked up . The gauges Are gone ill be replacing with autometer custom dash and buying aftermarket gauges . Yes I am aware of the 7.5 rearend mine is brand new rebuilt so I'm gonna give it all it can take for now until I find either a Posi or quick change possible 9' but the 8.8 would be easiest thanks for ur input !
Old 02-21-2013, 08:16 AM   #6
2Greeny7's Avatar
Send a message via Skype™ to 2Greeny7
Wow very very cool! If you don't mind me asking how much did this swap run you? I love the turn out of it! I'd love to see how the gauges came out!
2001 V6
CAI, SF3/X3 Tuner, 4.10 Gears, Auburn lim-slip
GT4 Rims (Summer), Stock Rims (Winter)
2 Subs, New speakers all around
1 Great Car 1 Happy Kid
July '12 Mustang of the Month
2Greeny7 is offline   Reply With Quote
Old 02-26-2013, 11:48 AM   #7
You can do this swap alot cheaper than I did . But I spent about 12 thousand mostly cause I did alot of custom stuff and drag racing parts throughout my build . My march pulley and bracket kit alone was 800 bucks . Trans controller was another 800 . I did my own head work and built it myself . The gauges work you just have to run ur wires to their new location . My Trans controller has a speedo output and I can adjust anything I've changed on it to calibrate the speed correctly . I'm about to ditch the gauge cluster anyways and get a autometer pod in its place and make a custom cluster . You can do this swap for about 2500-3 grand easily and ppl that say buy a cobra buy a gt dah dah they don't make any more horsepower than mine ? I'm actually making more than both of them ! All a cobra is good for is to say you have a cobra but what good is it if u get smoked by a once v6 car ! Reason I spent so much is I'm not getting rid of it and its what I like so it's worth it . Glad u guys enjoyed
1999 mustang
09:37 AM
