Vibrating clutch pedal? - Mustang Evolution
Old 02-08-2013, 06:06 PM   #1
96smoke's Avatar
Just had a new clutch put in (stock replacement) and everything was all good I thought. Didn't realize until that I had drove it home and was sitting in neutral, that the clutch pedal was rattling when idle. And if I barely touch it you can feel it vibrating. Before, this was never an issue. Also, if you're sitting in neutral and give it some gas and slightly touch the clutch pedal, not even pushing it in, you can hear a noise that sounds like something rotating and hitting something else. But if you just rev it and dont touch the clutch, you don't hear it. So what's the deal? Can't contact the guys who did the clutch and all until Monday so I figured I'd see about you guys opinions?
Keep in mind I do have an aftermarket clutch cable, firewall adjuster and quadrant. I had this installed for about 3 months before a new clutch was put in and it never rattled like this. Thoughts?
96smoke is offline   Reply With Quote
Old 02-09-2013, 12:35 AM   #2
02StangGT's Avatar
Sounds like the TOB I just replaced mine and the tob was defective
02StangGT is offline   Reply With Quote
Old 02-09-2013, 07:13 AM   #3
96smoke's Avatar
Interesting. How much was it for you?
Old 02-09-2013, 07:50 AM   #4
1996mustang's Avatar
If its a tob i should have been replaced along witht the install of the clutch.....that is if its a good shop they should have atleast told u that
Old 02-09-2013, 01:06 PM   #5
02StangGT's Avatar
I haven't replaced it yet my car is in the process if and engine swap. At autozone its like $15 for a new tob
Old 02-09-2013, 03:05 PM   #6
jjsg09's Avatar
I urge anyone changing out there clutch to replace the TOB with a Ford Racing one only. There are the best reliable one out there do not go cheap on that. You dont want to have to pull the tranny just for TOB again.
Old 02-09-2013, 05:29 PM   #7
96smoke's Avatar
Yeah I went and looked at my copy of what they did and they did replace the TOB. So what could it be now?
Old 02-09-2013, 10:41 PM   #8
Doesnt necessarily mean they did honestly i could charge u for a tob and not replace it and ur clutch will work fine. Seen it done alot in the automotive field. My suggestions get the tob replaced again as a defect or it may be the pilot bearing
---------- Post added at 12:41 AM ---------- Previous post was at 12:40 AM ----------
Did the flywheel get replaced or resurfaced?
Old 02-10-2013, 06:24 AM   #9
96smoke's Avatar
These guys are well known, I trust that they did it and Monday I'm going to go back and let them take a peak at it. Yesterday I drove it and it randomly stopped doing both of the things I described so it's got me stumped. But there's still a vibration behind the clutch pedal, like a foot massage lol.
Yes the flywheel was resurfaced.
Old 02-10-2013, 10:20 AM   #10
Then maybe its the breaking in of the clutch. That may be the way it feels for its break in period. Read up yesterday that any aftermarket clutches sometimes vibrate a bit when breaking in and they smooth out after the 500 mile break in
Old 02-10-2013, 11:02 AM   #11
96smoke's Avatar
Yeah I'm thinking I'll let it get closer to 500 before I worry too too much seeing as I've only gone about 100 if that
Old 02-10-2013, 01:08 PM   #12
Mile high JDF's Avatar
OP have you checked to make sure the TOB isn't resting on the pressure plate?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 02-10-2013, 08:40 PM   #13
96smoke's Avatar
I actually haven't. But tomorrow I will definitely check it out closer for sure.
03:37 AM
