Short throw - Mustang Evolution
Old 02-08-2013, 08:19 PM   #1
Rich04's Avatar
Short throw
Im seeing a lot of mgw assuming thats whats best to go with?
Just one question is it hard to get into reverse?
Only reason i ask is cause my friend has a gti and said its a pain " i alrrady know all vw's u have to push down before going into reverse"
Rich04 is offline   Reply With Quote
Old 02-09-2013, 12:19 AM   #2
Not a problem. Great improvement. Great shifter.
shottist is offline   Reply With Quote
Old 02-09-2013, 01:34 AM   #3
Rich04's Avatar
Thank you
Old 02-09-2013, 07:10 AM   #4
1shotkllz's Avatar
These transmissions are notoriously known for reverse issues. Just throw it in 5th, ease the clutch out to where it barely grabs, push the clutch back in and it pops right into reverse. Our transmissions inherited a design flaw, enough there was a TSB issued for it. I have a pro 5.0 and that ***** is like butter!
1shotkllz is offline   Reply With Quote
Old 02-09-2013, 07:36 AM   #5
COBRA97CW's Avatar
I'm thinking about getting a hurst for mine, any thoughts em?
COBRA97CW is offline   Reply With Quote
Old 02-09-2013, 08:24 AM   #6
AgentOrange's Avatar
I have a Hurst that I took out of my car. I wasn't a big fan of it honestly. If you're really considering one, let me know. You have a tr-3650 right?
AgentOrange is offline   Reply With Quote
Old 02-09-2013, 08:32 AM   #7
COBRA97CW's Avatar
I've got the t45 in mine
Old 02-09-2013, 10:02 AM   #8
Rich04's Avatar
I have a T56 trans , its not hard getting in to reverse. I just heard the short throw was if i do have a problem into 6th then R?
Old 02-09-2013, 10:57 AM   #9
I have the mgw orange on my t56, no issues with reverse. Make's 3rd a cake walk.
Old 02-09-2013, 11:05 AM   #10
2002VertGT's Avatar
MGW is awesome...I've had people that get in it not be able to find reverse...but it's a short throw...put some muscle in it and push that biotch all the way over them down...
4.10 Gear/RPM thread
Old 02-09-2013, 11:05 AM   #11
Cobrarunnin9s's Avatar
I have an MGW shifter with my t45 and I have a lot of trouble with reverse so much to the point I don't use it anymore at all really. T45's have a bad shift fork situation due to some non cnc machinist doing his job improperly. There are 3 different shift forks for 5th/reverse gears and its a pita to fix it in the car. Good shifter, ****ty transmission.
Cobrarunnin9s is offline   Reply With Quote
Old 02-09-2013, 11:07 AM   #12
v8pony's Avatar
I have the SR performance short shifter from AM..finds 3rd for you, I've driven an MGM, and tri ax, and too be honest, this SR is wayyyy better than a tri ax, and is up there with MGW...plus MGM could take a few weeks just to ship out to you, I got my SR 2 days after order..I love it
2002 5spd GT
Feb 2013 Mustang of the Month
Old 02-09-2013, 11:21 AM   #13
1shotkllz's Avatar
Exactly.
Old 02-09-2013, 11:45 AM   #14
BeachMonkey100's Avatar
I have the hurst and I have had no problems with getting into 3rd or reverse. It is notchy but it's a short throw what do you expect. Other than that it's a great piece.
2006 Mustang GT Premium Satin Silver Metallic | 5 Speed Manual | Hurst Short Shifter | K&N CAI | JSR Strut Brace, FLCA Brace, Rear Shock Tower Brace | Flowmaster Axle Backs | Ford K Springs | JM Trackbar | 93 Bama Performance Tune
BeachMonkey100 is offline   Reply With Quote
Old 02-09-2013, 02:14 PM   #15
cliffyk's Avatar
And a VW GTI has what at all to do with a Mustang GT?
Old 02-09-2013, 02:30 PM   #16
bullitt1075's Avatar
Send a message via Skype™ to bullitt1075
Get the MGW.
Proud owner of Bullitt #1075
bullitt1075 is offline   Reply With Quote
Old 02-09-2013, 03:56 PM   #17
Rich04's Avatar
I was saying he said its hard to get into reverse cause of his short throw. And im pretty sure iv seen that sometimes its a pain.
Old 02-09-2013, 04:41 PM   #18
cliffyk's Avatar
It very well may be, however I repeat--what does a wrong-wheel-drive Euro econobox have to do with a New-Edge Mustang?
Old 02-09-2013, 06:01 PM   #19
Rich04's Avatar
Because i wanted to know if it would be hard to get into reverse or not .. I had a question to ask and used that as an example..
Like cobrarunnin9s said.
Old 02-09-2013, 06:46 PM   #20
If your tranny doesn't go into reverse right now getting any shifter will not help. If it does... Get the mgw and call it a day.
Old 02-09-2013, 06:50 PM   #21
Rich04's Avatar
It has its days. Im just trying to explain this to cliffy
Old 02-09-2013, 07:05 PM   #22
He knows what's up, the shifter in that vw your talking about isnt like the one in the t45. It probably uses 2 cables like most fwd cars do. There would be no comparison.
Old 02-09-2013, 07:10 PM   #23
Rich04's Avatar
Yeah but i was just trying to explain the shifter. I don't have any other friends with short shifters.
Old 02-09-2013, 09:14 PM   #24
Just stick the thing in first, roll forward a few inches and try again to grab reverse.
Old 02-09-2013, 09:34 PM   #25
v8pony's Avatar
+1
2002 5spd GT
Old 02-10-2013, 08:36 AM   #26
jdavis96gt's Avatar
Region: West Virgina
Try first to second then reverse. That works for me.
Old 02-10-2013, 09:30 AM   #27
cliffyk's Avatar
The first thing to do is change the tranny fluid, using only 3.0 L (3.2 qt) when refilling--per TSB 04-15-6--here is the 2004 MY TSB 04-26-13.
They came filled with 3.8 L (4.0 qt) from the factory which was found to be too much, causing hydro-locking off the shift rods and detents, with similar effects on synchro engagement.
Having used Mercon, RP Synchromax and Mobil 1 ATF I find I prefer the M1 as it provides the smoothest shifting of the three.
With that done it may still take a quick release of the clutch in neutral to get the main shaft spinning, or the other suggestions made above to get into reverse. This is common with higher torque capacity transmissions. If those tricks do not work then it could of course be that the transmission has failed...
10:17 AM
