Stupid Question - Mustang Evolution
Old 07-14-2008, 11:17 AM   #1
1234's Avatar
Stupid Question
What gears do i have? Its stock. On 03 GT manual.
What gears do you recomend?
Is it a bolt in procedure?
Old 07-14-2008, 11:27 AM   #2
Re: Stupid Question
you have 3.55 gears, i like 4:10s on n/a cars for sure. far from a bolt in,have them installed, you have to check backlash and pinion depth.
SimplyOrange is offline   Reply With Quote
Old 07-14-2008, 11:27 AM   #3
Re: Stupid Question
You have 3.27 gears.
Recommend 3.73's...you could go 4.10's, but 3.73s are my suggestion since it is a manual.
It is no different than any other gear swap. Not really a "bolt in", you do have to make sure things are within tolerances.
Old 07-14-2008, 11:27 AM   #4
Re: Stupid Question
3.55 in 03-04, why do yall hate 4.10s? geeze!!!
Old 07-14-2008, 11:29 AM   #5
Re: Stupid Question
Cobras....the GTs were still 3.27's as far as I remember. I'm looking it up now.
Old 07-14-2008, 11:30 AM   #6
Re: Stupid Question
k, im not 100% sure but i thought the gts were too.4.10 hater!
Old 07-14-2008, 11:31 AM   #7
Re: Stupid Question
I don't believe the GT's saw a change until 05...I believe 99-04 were all the same...3.27's. Naturally, searching for this is a PITA.
Old 07-14-2008, 11:31 AM   #8
1234's Avatar
Re: Stupid Question
Are either 4:10s or 3:73s going to drastictly affect my top end?
Old 07-14-2008, 11:32 AM   #9
Re: Stupid Question
not much
Old 07-14-2008, 11:59 AM   #10
1234's Avatar
Re: Stupid Question
Tps your shop sell em?
Old 07-14-2008, 12:05 PM   #11
Re: Stupid Question
yup, but im outta stock right now, new order should be in soon.
Old 07-14-2008, 12:12 PM   #12
1234's Avatar
Re: Stupid Question
What do ya charge for buying and installation at your shop?
Old 07-14-2008, 12:15 PM   #13
Re: Stupid Question
You definitely have 3.27 stock. I'd recommend at least a 3.73. Don't fear the gear though, if you're gonna do it go all the way to a 4.10. As far as top end...no need to go over what a 4.10 will enable you.
Old 07-14-2008, 12:15 PM   #14
Re: Stupid Question
about 550 total with fluid, friction modifier, new pinion bearing, gears, new pinion seal, and labor
Old 07-14-2008, 12:16 PM   #15
Re: Stupid Question
Just as a side note, our site sponsor Atomic Performance - TA Performance, Pro 5.0, SCT, C&L, JLT Cold Air also has the 3.73 and 4.10 gears available and most likely in stock. Not to diss TPS, but Atomic is a site sponsor where TPS isn't yet.
Old 07-14-2008, 12:19 PM   #16
1234's Avatar
Re: Stupid Question
Thats what i was thinking just wasnt sure. Thanks for the advise.
Guess im coming down to Baton Rouge.
Old 07-14-2008, 12:22 PM   #17
Re: Stupid Question
I know when you should come.
http://www.mustangevolution.com/forum/t32535/
Old 07-14-2008, 12:26 PM   #18
1234's Avatar
Re: Stupid Question
I want to but cant get off work.
Old 07-14-2008, 12:40 PM   #19
Re: Stupid Question
yea, ive been told our prices are too cheap to stay in buisness so we managed to get a dyno that bought itsself
Old 07-14-2008, 12:41 PM   #20
1234's Avatar
Re: Stupid Question
Works for me.
Do i have to get the speedo corrected after the gears are put in?
Old 07-14-2008, 12:43 PM   #21
Re: Stupid Question
Yes, you'll need to update your tune for the new gears...or get a tune for the new gears if you don't have a tune yet.
Old 07-14-2008, 12:44 PM   #22
Re: Stupid Question
Old 07-14-2008, 12:44 PM   #23
1234's Avatar
Re: Stupid Question
Who does that? Or should i just pick up an sct programmer?
Old 07-14-2008, 12:45 PM   #24
Re: Stupid Question
we have them here also, granatelli, predator and sct.
Old 07-14-2008, 12:47 PM   #25
1234's Avatar
Re: Stupid Question
Good to know
Old 07-14-2008, 12:48 PM   #26
Re: Stupid Question
we could dyno tune it as well while you are here.
Old 07-14-2008, 12:50 PM   #27
Thomas91169's Avatar
Re: Stupid Question
Stock gears for manual 99-04 GT's are 3.27's.
Gearing is dependent on goals. For a boosted setup, 3.73's IMO. Bolton only (and possible nitrous), go with 4.1's. Dont know yet? go 3.90's.
Id find a stang worthy shop in your area that can also modify your tune to account for the gears. Most regular tranny shops though can install gears no problem. Might also want to pick up a rebuild kit.
-Thomas-
Old 07-14-2008, 12:50 PM   #28
1234's Avatar
Re: Stupid Question
I would prefer that. Whats that run?
Old 07-14-2008, 12:59 PM   #29
Re: Stupid Question
im not sure just yet,we are still going over our prices but ill have them posted by the time you are ready.we are having the dyno installed this weekend.
Old 07-14-2008, 01:02 PM   #30
1234's Avatar
Re: Stupid Question
Sweet ill get in touch with you before i come down. I'm thinking some time next month.
Old 07-14-2008, 01:05 PM   #31
Re: Stupid Question
we will def be ready then.
Old 07-15-2008, 10:43 AM   #32
Re: Stupid Question
I put a 3.73 in my '97. I loved it at first, but soon after I wished I had gotten a 4.10. Don't be afraid to be aggressive.
Don't forget to get the rear end additive from Ford. It'll make the diff fluid last much longer (recommended 100k changed instead of 30k change with it)
mustanggt is offline   Reply With Quote
Old 07-15-2008, 11:10 AM   #33
1234's Avatar
Re: Stupid Question
The thing that worries me is cruising at 75 is my motor going to be wrapped out?
Old 07-15-2008, 02:39 PM   #34
Re: Stupid Question
Before you make a final decision on your gears, you should know what your goal is with your car. If you are going to be boosting or spraying you may want to stay with the 373, if you have no intention of either then Id go 410. The 390 gears would be the best gear in my opinion to run no matter what you are going to be doing with future mods.
Benjytps is offline   Reply With Quote
Old 07-15-2008, 02:45 PM   #35
Send a message via AIM to black98gtvert
Re: Stupid Question
i run 3.73 in my 98 and i come no where near wrapping out do 85 at 2.5 if i remember correctly
98 GT Vert
Mods: MAC CAI,FLOWS 40 series,MSD Wires and Coils,"MM"starter box susp, MAC underdrive pullies, BBK off-road X, Steeda TRI-Ax, 3.73 gears, Sniper Special Forces Tuner, Accufab 75mm TB and Plenum, and a ZEX __ Shot
04 CBR F4i: A Street Machine on roids
black98gtvert is offline   Reply With Quote
stupid question...... JTATE300 Pre-2005 V6 Mustang 36 04-14-2010 02:32 PM
stupid question SaturnMan8227 Pre-2005 V6 Mustang 0 01-20-2009 11:43 PM
this maybe a stupid question.. iwannagofast Pre-2005 V6 Mustang 25 05-27-2007 02:26 AM
here goes a stupid question Kyle Pre-2005 V6 Mustang 9 03-13-2007 08:08 PM
Stupid Question.... tkd_gt 1996-2004 Mustang GT 23 08-05-2006 10:50 AM
06:45 PM
