Looking at suspension upgrades - Mustang Evolution
Old 02-11-2013, 11:51 AM   #1
Speed_Mister's Avatar
Region: Arkansas
I'm thinking about some suspension upgrades wondering who has launching springs or shocks and struts or control arms that helped in 1/4 mile et's and by how much. Thanks.
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 02-11-2013, 12:07 PM   #2
Venomouz831's Avatar
What all you have done to you're car and what are you're 1/4 mile times
)02 Gt, Founder of WE2G
Old 02-11-2013, 12:20 PM   #3
Region: Arkansas
Cold air intake, 75mm tb/p, tb spacer, udp, o/r x-pipe, 93 bama race tune, Clutch, 4.10's, 31 spline axles and differential and Hoosier slicks. Flow master mufflers. Now I have no mufflers (running open midpipe) I go to 1000ft track run a 10.65 I'm guessing a 12.6-12.8 in 1/4.
Full Bolt Ons
370rwhp 470rwtq
Old 02-11-2013, 12:31 PM   #4
That's preety good if you hit the 12's. what suspension do you have because that plays a role
Old 02-11-2013, 12:32 PM   #5
Region: Arkansas
i have completely stock suspension. thats why i want to see whats out there and what would help me lower my 1/4 mile et
Full Bolt Ons
370rwhp 470rwtq
Old 02-11-2013, 01:09 PM   #6
Rear upper and lower control arms should help your launch quite a bit.
Old 02-11-2013, 01:10 PM   #7
Region: Arkansas
Any difference in 1/8, 1000ft or 1/4?
Full Bolt Ons
370rwhp 470rwtq
Old 02-11-2013, 01:10 PM   #8
1slosix's Avatar
One of the quickest NA GTs i know runs cut springs... which makes sense seeing how they transfer weight so nicely...added drag bags of course...F8L GT on MM
carving corners like a boss
Old 02-11-2013, 01:11 PM   #9
I've got no experience with them, but they help with your rear end sinking in when you launch hard.
Old 02-11-2013, 01:12 PM   #10
Region: Arkansas
How much were they cut off in rear and front?
Full Bolt Ons
370rwhp 470rwtq
Old 02-11-2013, 04:08 PM   #11
1slosix's Avatar
If i recall he is running 1.5 coils off the front and no coils off the back to give the back plenty of room when it launches. He may have cut some from them since i last talked to him but doubtful with his big slicks
Old 02-11-2013, 05:03 PM   #12
Rosco's Avatar
LCA's will help with wheel hop, it's bushings that do it. Stock bushings are rubber and cause binding. A panhard bar also helps with binding and wheel hop. Have you done weight reduction?
1998 Bright Atlantic Cobra - 3:73's, BBK ls, Pro 5.0, 96 Cobra STB, Borla XR-1 Catback, Custom Catch Can, Spec clutch, MM Firewall adj, FRPP wires, RSD, Spoiler delete, 245/275 BF Goodrich g sports on chrome 95 cobra r's
1998 V6 Mustang : SOLD!
Rosco is offline   Reply With Quote
Old 02-11-2013, 05:36 PM   #13
Region: Arkansas
So he cut of 1.5inches in front and none in rear on stock springs.?
I have done lots of weight reduction. I have slicks also.
And with all this it should help my times go down..? I also found Lakewood drag struts and shocks for 150. 70/30 struts and 50/50 shocks. Good deal?
Full Bolt Ons
370rwhp 470rwtq
Old 02-11-2013, 07:11 PM   #14
1slosix's Avatar
well after looking his newer pics over it looks like he's probably cut about a coil off the back since the last time i've seen it
Old 02-12-2013, 05:01 AM   #15
Region: Arkansas
Is he running with any sway bars?
Full Bolt Ons
370rwhp 470rwtq
Old 03-21-2013, 12:52 AM   #16
Region: Arkansas
Yes I've done lots of weight reduction. I record my races and after doing a hard launch I see my car rocking hard like its bad thinking some suspension mods would help. And I'm gutting my car and hopefully delete my steering wheel pump and ac condenser, for the new drag racing season.
Full Bolt Ons
370rwhp 470rwtq
10:54 AM
