Pulley's - Mustang Evolution
Old 07-15-2008, 11:38 AM   #1
03GTNEWB's Avatar
Send a message via AIM to 03GTNEWB
Exclamation Pulley's
Okay...i'm buying these in about 20 mins. Wanted any kind of info i can get as quickly as I can. Easy question...BBK or Steeda U.D. Pulley's? Which would you chose and why? I'm leaning toward the BBK because they are a bit cheaper and they're polished. Will the aluminum BBK ones bend under extreme pull? I know the Steeda ones are made of steel so obviously they would be the stronger of the two. But do I really have to worry about alum. ones warping or bending or breaking? Any help would be FANTASTIC! Thanks again.
Where are we going...and why am I in this hand basket?
Mods: Not many...but more to come. K&N CAI, Flowmaster exhaust, FR500 18x10's/18x9's staggered with G Force Tires, 3:73 gears, little odds and ends that are stupid but kinda separate my pony from the ENORMOUS HEARD of them out here in DC/VA/MD area.
03GTNEWB is offline   Reply With Quote
Old 07-15-2008, 11:40 AM   #2
1234's Avatar
Re: Pulley's
You dont have to worry about them bending warping or braking. Unless your trying to pry your belt on. I would go with BBK. They both do the same thing.
Old 07-15-2008, 11:51 AM   #3
03GTNEWB's Avatar
Re: Pulley's
Another question...will I need a pulley puller to get my stock pulley's off or are they direct bolt on bolt off pulley's? What exactly will I need for this???
Old 07-15-2008, 11:57 AM   #4
1234's Avatar
Re: Pulley's
The alternator and water pump unbolt and pop off. Its a bit of a ***** holding the alternator pulley still while trying to unbolt it. The crank pulley, you need a puller. Not sure if it comes with a power steering pulley, definitly need a different piullier for that one. but someone will correct me if im wrong.
Old 07-15-2008, 12:42 PM   #5
Send a message via AIM to black98gtvert
Re: Pulley's
bbk or mac either of the two are nice its an easy job and youll notice the differnece
98 GT Vert
Mods: MAC CAI,FLOWS 40 series,MSD Wires and Coils,"MM"starter box susp, MAC underdrive pullies, BBK off-road X, Steeda TRI-Ax, 3.73 gears, Sniper Special Forces Tuner, Accufab 75mm TB and Plenum, and a ZEX __ Shot
04 CBR F4i: A Street Machine on roids
black98gtvert is offline   Reply With Quote
Old 07-15-2008, 01:57 PM   #6
Herbstang's Avatar
Re: Pulley's
This may give ya a idea of what you need Steeda Tech Tips
Old 07-15-2008, 02:19 PM   #7
Re: Pulley's
Id go with the aluminum to save a little on the rotating weight. You dont have to worry about bending,breaking cracking. I have ran aluminum on our 86 gt shop car for nearly 10 years now.
Benjytps is offline   Reply With Quote
Pulley's for an 05 Mustang Hollis316 Pre-2005 V6 Mustang 7 03-19-2007 11:06 AM
05:56 AM
