Supercharger help - Mustang Evolution
Old 02-13-2013, 08:04 PM   #1
2002VertGT's Avatar
Supercharger help
Ok, So today I picked up my Procharger P1sc. I got it locally from a guy who bought it and never used it and needed $ to fix his SRT4. EVERYTHING is still new in packaging. The Oil box had never been opened and the head unit had not even had oil put in it. Everything else is sealed. Got it all for $2600. Now,
I know I need new fuel injectors. I found a set locally on CL for $150 (39lb ford racing injectors). I know I will have to buy the Adapters for these. I know I will need a new fuel pump. Do I buy and install a second one like they show in the install video on AM? or can I get away with just installing a SVT Focus 255lph fuel pump? Do I need to get a new MAF or can the one I have work? I don't remember hearing them say you needed a new one. Just need to know what I need to get together so I can get it all together.
current mods on the car:
BBK CAI
BBK 78mm TB/P
Mac Pro Chamber
Mac Catback
93 OCT tune from SCT
---------- Post added at 10:04 PM ---------- Previous post was at 10:03 PM ----------
I am planning on having it tuned to run a mild tune and get around 400-430 hp
4.10 Gear/RPM thread
Old 02-13-2013, 08:12 PM   #2
CodyNelson's Avatar
Region: West Virgina
255 pump will get you to 390-400rwhp without a boost-a-pump. And get the 42lb injectors.
---------- Post added at 10:12 PM ---------- Previous post was at 10:09 PM ----------
And congrats! Welcome to the world of Centri blowers!! It's a blast. You will need some headers and 12 of boost to get you to the 415-430 range
Old 02-13-2013, 08:12 PM   #3
2002VertGT's Avatar
Is 3# really that big of a difference? Do I also need high flow fuel rails?
Cody you need to pm me your phone # so we can text back and forth about this
Old 02-13-2013, 09:10 PM   #4
2002VertGT's Avatar
The reason I was going to go with 39 was I can get some for 150...and apparently guy's are the only 94-04 mustangs with ev1's so I would have to buy the 34$ adapters
Old 02-13-2013, 10:42 PM   #5
Jredherr's Avatar
Buy ford lighting 42 injectors and no adapters needed. You can find them cheep.
Jredherr is offline   Reply With Quote
Old 02-13-2013, 11:18 PM   #6
2002VertGT's Avatar
Where?
Old 02-14-2013, 03:15 AM   #7
Jredherr's Avatar
Where?
Start with Craigslist !
Old 02-14-2013, 04:31 AM   #8
Rm360's Avatar
I would get the Lincoln aviator fuel pump it flows at 285 + LPH , and I would run a BAP for safety, I would also upgrade the maf to a 90 mm , stock one pegs out at 360 hp, that being said you can use the stock maf and run diablo sport mafia interface unit it lets the sensor read the air intake differently, ( I would just get a new maf ), your fuel rails will be good and like Cody said LT's and at least 42lb injectors , I would upgrade the cai as well to a jlt or Anderson power pipe
Old 02-14-2013, 05:54 AM   #9
CodyNelson's Avatar
Pm sent. As said above the 42# injectors will be much easier for you to use and they will support more power. The aviator and focus pumps are almost identical. But feel free to text me anytime
Old 02-14-2013, 06:14 AM   #10
2002VertGT's Avatar
Ugh....more and more $ I don't have...can y'all help me find some of this stuff? Boost a pumps are 250ish? Injectors I dunno, 400ish new...fuel pump 1-200...
Old 02-14-2013, 06:25 AM   #11
02PONY's Avatar
Search Craigslist people would most likely ship these to u beings they are smaller items and don't weigh much. Also have u checked any other forums like modded mustangs and corral ? I've found stuff cheaper over on those sites.
02PONY is offline   Reply With Quote
Old 02-14-2013, 06:39 AM   #12
Jredherr's Avatar
You can find lightning 42 lbs for $100-175. I have focus pump for $100. I just put a 03 cobra system in so don't need it anymore. Try eBay or Craigslist that's where I get all my stuff for over half price. Good luck
Old 02-14-2013, 06:53 AM   #13
WheelStander's Avatar
Get the BBK 300 fuel pump from Lethal, it's a direct bolt up and only 289.
Induction: Kenne Bell | wHp: 515 Tq: 503 | 1/4 Mile:11.09@123
WheelStander is offline   Reply With Quote
Old 02-14-2013, 06:54 AM   #14
CodyNelson's Avatar
I've for a 255 pump with less than 1000 miles on it. Good for 400 at the wheels. I only took it out because I got a steal on a cobra hat and twin pump setup.
Old 02-14-2013, 06:54 AM   #15
Don't use Bap, proven loser.
Old 02-14-2013, 06:56 AM   #16
CodyNelson's Avatar
+1 with your current mods the focus pump alone will cover your needs. Then you can consider upgrading later down the road
Old 02-14-2013, 07:27 AM   #17
Rm360's Avatar
How so?
Old 02-14-2013, 08:09 AM   #18
Too much to explain on phone.
Ah it just is, lots of reasons.
Basically the Bap can only queue so much fuel and once that queue is empty you're left with you pump lph.
---------- Post added at 10:09 AM ---------- Previous post was at 10:08 AM ----------
You can see it on Bap dyno sheets.
---------- Post added at 10:09 AM ---------- Previous post was at 10:09 AM ----------
It's a flutter at the end of the power curve.
Old 02-14-2013, 08:23 AM   #19
Rm360's Avatar
The BAP was supposedly designed to work with a stock fuel pump to " drive"it on the top end so you wouldn't run out of fuel, problem is that at wot the stock fuel pump is maxed out , you are right on it running out of fuel that is basically due to the fuel pump and not the BAP, the way it should work is have a fuel pump that puts out enough LPH to support your power level and use the BAP as a safety mechanism to ensure top end flow without any dips, for me it's a $250 peice of mind
Old 02-14-2013, 08:27 AM   #20
Agreed
---------- Post added at 10:26 AM ---------- Previous post was at 10:25 AM ----------
Luckily I got some dual cobra pumps for 200 I'm putting next week.
---------- Post added at 10:27 AM ---------- Previous post was at 10:26 AM ----------
Those are 370 lph I think.
Old 02-14-2013, 08:27 AM   #21
2002VertGT's Avatar
Picked up some 42lv green tops for 150
Old 02-14-2013, 08:31 AM   #22
Nice
Old 02-14-2013, 08:50 AM   #23
Jredherr's Avatar
Good buy , Craigslist or eBay ?
Old 02-14-2013, 09:02 AM   #24
Rm360's Avatar
Agreed
Both awesome deals right here!!!
Old 02-14-2013, 09:57 AM   #25
2002VertGT's Avatar
Corral
Old 02-14-2013, 10:34 AM   #26
Jredherr's Avatar
Corral
Cool man , I am running same injectors they come stock in the newer lightning's. I also have a focus fuel pump for sale.
Old 02-14-2013, 11:11 AM   #27
2002VertGT's Avatar
Ok, so a focus pump will only give me up to 400hp? I saw on AM video where they put a second pump in with the first one on a gt. could I do this with two svt pumps?
Old 02-14-2013, 12:33 PM   #28
2002VertGT's Avatar
Fun filled pic for you guys...
Old 02-14-2013, 12:40 PM   #29
Rm360's Avatar
Those guns are sweet! What kind is the little black one on the left?
Old 02-14-2013, 12:47 PM   #30
2002VertGT's Avatar
Springfield XDS .45 subcompact. Literally 1" thick at its widest point.
ID:	90911   Click image for larger version
Old 02-14-2013, 01:00 PM   #31
Rm360's Avatar
How is the recoil of the Springfield compared to the Ruger? Would a women have a pretty easy time shooting it?
Old 02-14-2013, 01:18 PM   #32
2002VertGT's Avatar
I dunno, lol...just got it yesterday and have not actually shot it yet.
The Ruger is a breeze. My sister shot it for her first time ever shooting when she was 18 and had all but two rounds inside the 7 ring....the other two were in the neck of the paper dummy...
Old 02-14-2013, 01:46 PM   #33
Rm360's Avatar
My wife shot the Ruger a few times with almost the same results, the only thing she said it feels a bit wide in her hands, she has little hands lol ! after you shoot that Springfield let me know what you think about it
Old 02-14-2013, 01:53 PM   #34
2002VertGT's Avatar
Sure will!
Old 02-14-2013, 02:21 PM   #35
Rm360's Avatar
Sure will!
Thanks!!!
10:43 AM
