Ac compressor question? - Mustang Evolution
Old 02-14-2013, 08:54 AM   #1
Mathew r Wright's Avatar
Hey guys/gals got this question? My ac compressor squeals and squals or whatever. I was woundering what I can do about that without opening the system? Is it like clutches that can be changed?
Mathew r Wright is offline   Reply With Quote
Old 02-14-2013, 01:34 PM   #2
Mfore33's Avatar
Sounds like the clutch bearings are bad. I don't know if you can just replace the clutch without getting a new compressor.
Old 02-14-2013, 01:52 PM   #3
CrimsonGT's Avatar
Just the clutch can be changed been there done that myself wasn't a big deal at all
CrimsonGT is offline   Reply With Quote
Old 02-14-2013, 05:08 PM   #4
cliffyk's Avatar
Here is the shop manual RnR for the idle pulley and clutch coil. The coil is likely OK.
This can all be done on the car, it's just that the working quarters can be a bit tight. You may have to pull the radiator if the coil needs to be removed with a puller.
Old 02-14-2013, 05:28 PM   #5
Slow4V's Avatar
Clutch is easy to Do, just make sure you use the correct shims , if not it will burn the clutch up again.
Old 02-14-2013, 05:42 PM   #6
cliffyk's Avatar
+1, if you need additional shims to get it right go by any auto AC shop, they will usually give you a few of assorted sizes for free...
Old 02-14-2013, 06:36 PM   #7
K thanks guys and I'm assuming that I can get these clutch part for autozone or O'Rieley's...
Old 02-14-2013, 07:05 PM   #8
CrimsonGT's Avatar
I got mine at oreily's
05:26 PM
