Manifold - Mustang Evolution
Old 02-14-2013, 09:46 PM   #1
MineralGrayGT's Avatar
Region: Wyoming
Manifold
Signs of a cracked intake manifold? Hissing noise maybe?
MineralGrayGT is offline   Reply With Quote
Old 02-14-2013, 09:47 PM   #2
Slow4V's Avatar
Hissing ?
Any other noticeable problems ?
Old 02-14-2013, 09:49 PM   #3
Region: Wyoming
All im hearing is a hissing sound. Sounds like its coming from behind the throttle body kinda? But not noticing any other problems like lack in power or anything
Old 02-14-2013, 09:52 PM   #4
Slow4V's Avatar
Hmmm should be fine .. If you notice lack of power and bad MPG .. things like that then worry.
Old 02-14-2013, 09:57 PM   #5
Region: Wyoming
Alright ill deffinetly watch out for that stuff. Thanks man
Old 02-14-2013, 10:00 PM   #6
Slow4V's Avatar
Just message me if you need help
Old 02-16-2013, 07:42 AM   #7
1996mustang's Avatar
Hissing may be an intake leak however u will feel a loss of power if u had it. If its by the throttle then it may just be a gasket but if ots not affecting performance maybe its nothing but the sound of air going in the manifold
02:45 AM
