Need some advice on brake pads - Mustang Evolution
Old 02-14-2013, 11:52 PM   #1
Mfore33's Avatar
Well It's time to replace the front brakes on my 2000 GT and I need advice on brake pads. Motor is stock and its an auto and daily driver. I'm just looking for some better stopping power. I don't know if I'll get the stock solid rotors or some cross drilled and slotted ones. What are the best pads for both applications and for street use? Thanks in advance.
Old 02-15-2013, 12:58 AM   #2
Venomouz831's Avatar
Hawk pads
)02 Gt, Founder of WE2G
Old 02-15-2013, 01:28 AM   #3
Mfore33's Avatar
Any particular ones from hawk?
Old 02-15-2013, 04:20 AM   #4
jdavis96gt's Avatar
Region: West Virgina
There's pretty good deals on drooped &slotted rotors+ pads on eBay. Come with year warranty on warping. Plus lifetime warranty on breaking.
Old 02-15-2013, 08:10 AM   #5
Hawk or EBC are your most popular brands for pad slaps.
DieselStang is offline   Reply With Quote
Old 02-15-2013, 08:17 AM   #6
Slow4V's Avatar
Pads are all the same .. Go get regular pads at your local store .. Pads aren't going to make a difference , neither will rotors unless your upgrading to Mach or cobra brakes
Old 02-15-2013, 08:23 AM   #7
Slow4V's Avatar
Your just paying for the brand name ..
I've had drilled and slotted rotors and hawk pads .. I couldn't even tell the difference from my stock set up.
Old 02-15-2013, 08:24 AM   #8
jdavis96gt's Avatar
I'd try to get ceramic pads, less dust.
Old 02-15-2013, 08:27 AM   #9
Pads are definatley not made equal. However I agree that pads wont make a noticeable difference in braking distance unless your corner carving for time on a track. Upgrading to bigger brakes would be the most effective way to improve your braking.
Old 02-15-2013, 09:12 AM   #10
Ewokjax95's Avatar
Drilled and slotted rotors just look too cool not to get and if you've never changed rotors, I think you'll see a difference. SS brake lines are also a good investment. Will take away some sponginess
Ewokjax95 is offline   Reply With Quote
Old 02-15-2013, 09:18 AM   #11
+1 on ss brake lines making a firmer pedal.
Old 02-15-2013, 09:21 AM   #12
WheelStander's Avatar
+1
WheelStander is offline   Reply With Quote
Old 02-15-2013, 09:41 AM   #13
Slow4V's Avatar
Originally Posted by WheelStander View Post
+1
I've had Drilled and slotted rotors .. No difference besides looks
Just trying to save the OP some money , so he can invest in 13" brake setup ..
You can be lucky and find them used
Old 02-15-2013, 09:52 AM   #14
Ewokjax95's Avatar
Old 02-15-2013, 10:18 AM   #15
Mile high JDF's Avatar
Drilled and slotted rotors are for dissipating heat better. They really aren't necessary until you get on a track and even then drilled rotors aren't very good for that because they crack under the stress.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 02-15-2013, 05:18 PM   #16
Mfore33's Avatar
Ok so stock rotors and hawk pads it is then. Thanks guys.
03:29 AM
