Heads Help - Mustang Evolution
Old 02-18-2013, 12:53 PM   #1
MustangGT02's Avatar
Heads Help
Just pick up heads for a great price and he told me they are ported and I know what that means but what does "valves have been undercut, they have had a 5 angle valve job, and have been milled 20 thousandths" mean?
Also they say essex on them, is that windsor?
MustangGT02 is offline   Reply With Quote
Old 02-18-2013, 01:01 PM   #2
BeachMonkey100's Avatar
Undercut valves are being referred to as the stems. Some use stock valves and some use undercut stems. You really need to have them flowed to know what you want and what application they are being used for. Since these are already in the head I'm assuming whoever did it flowed the head and they are better for many different reasons. So .020 has been removed from the stem of the valve where it tapers. Basically it's a narrower stem. 5 angle valve job would be referring to in most cases the valve and seat. The seat instead of being cut on one angle it is cut on 5 to improve flow characteristics. Hopefully that sums it up!
2006 Mustang GT Premium Satin Silver Metallic | 5 Speed Manual | Hurst Short Shifter | K&N CAI | JSR Strut Brace, FLCA Brace, Rear Shock Tower Brace | Flowmaster Axle Backs | Ford K Springs | JM Trackbar | 93 Bama Performance Tune
BeachMonkey100 is offline   Reply With Quote
Old 02-18-2013, 01:56 PM   #3
That helps, thanks for the info.
Old 02-18-2013, 02:02 PM   #4
No problem!
05:56 AM
