Using normal Power steering fluid - Mustang Evolution
Old 02-18-2013, 12:09 PM   #1
Wshewan's Avatar
Would it be okay to use just normal prestone power steering fluid instead of the ATF?
Wshewan is offline   Reply With Quote
Old 02-18-2013, 03:00 PM   #2
1996mustang's Avatar
Typically our cars use atf type f for power steering. Imo i would stay with what i came with due to how its made.
Old 02-18-2013, 05:22 PM   #3
cliffyk's Avatar
I would not as the p/s fluid is also used by the HydroBoost brake system. Ford says use Mercon ATF, that is what I would use, or some equivalent fluid...
04:28 AM
