02-20-2013, 11:04 AM
#1 | | Registered User
| 2004 3.9l convert to 4.6l
Hello I wondering what all I would need to convert my 2004 v6 to a 4.6l. I already have a 03 cobra v8 but what else would I need to complete my project besides a rear end?
02-20-2013, 11:10 AM
#2 | | Registered User
Which 4.6 engine are you speaking of swaping? A 4.6 2v or are you going to put a cobra motor in the sixer?
02-20-2013, 11:15 AM
#3 | | Registered User
ECU
Harnesses
Transmission
Driveshaft
Rear end
Axles
Alot .. Not worth it IMO
02-20-2013, 11:34 AM
#4 | | Registered User
Goin to put a cobra engine in the sixer
02-20-2013, 11:48 AM
#5 | | Registered User
My next questions after that will be what specific parts do you have already? You said you have a 03 cobra v8 so im assuming thats the cobra engine your going to swap. How complete is the engine does it have the supercharger and throttle body, exhuast headers? Do you have any other parts with it like intercooler, intercooler expansion tank etc? If your not sure of what you have pictures are worth a thousand words.
02-20-2013, 11:51 AM
#6 | | Registered User
I have all the parts to make it run except I new a transmission ---------- Post added at 01:51 PM ---------- Previous post was at 01:51 PM ---------- And it don't have a supercharger
02-20-2013, 12:11 PM
#7 | | Registered User
I beleave your v6 came factory with a T-45 if its a manual car. If so you can use a belhousing adapter and tranny cross member to bolt it to the cobra motor. However it wont be as strong as the T-56 the 03 cobra was made with and may need to be sent to a trans shop to be modified to take the extra horsepower and torque. If the v6 car is an automatic a good replacement would be a presure shifted automatic trans (not electronic) since the 03 cobra was never made with an automatic ECU. If your car has an automatic which I beleave is an AOD-E it will not work for the swap. I would suggest a C-4 or Turbo400 with a custom transmission adapter plate and custom tranny cross member for a pressure shifted auto trans if an auto is what you want. Also unless you go with the T-56 a custom driveshaft will be required. If you use a T-56 you will still have to aquire a custom or cobra tranny crossmember and driveshaft. For a cobra supercharger Ebay has been a good source for factory cobra superchargers in the past and still should be. If not many aftermarket replacements are available. And you will also need to consider how you are going to wire your tach as the v6-03cobra tachs are different. For this I would suggest keeping your stock tach and getting a separate boost gauge to mount inside or you could just run no boost gauge but its up to you. I will continue to answer questions as you have them.
02-20-2013, 12:18 PM
#8 | | Registered User
Ok mines a manual so Ill just upgrade my tranny and once I get a new Ecu, harnesses, tranny, driveshaft, rear Ed, and axles I could drive the car like it was a v8?
02-20-2013, 12:34 PM
#9 | | Registered User
Your radiator will need to be upgraded to the stock cobra unit or an aftermarket unit to support the extra horsepower. The 03 cobra was made with an IRS rear end but this was done by ford to help balance the engine. Your stock 4 link style 8.8 rear will work without any upgrading but you will need to use 3.55 gears to keep from using an aftermarket tuner with the 03 cobra ECU. Furthermore the 4link your v6 car has will give you better performance than the cobra IRS setup by about 2 tenths a second in the quarter mile just becasue its lighter and creates more traction. The 03 cobra engine block is also forged iron and weighs about the same as a 460 engine, this means you will need 03 cobra front springs to make the car driveable and I recomend using stock GT springs on the rear. Also to use your current manual trans you will need a custom tranny crossmember, a company called stifflers makes one that should fit your application. A custom driveshaft will need to be used as well. I recomend moser 33 spline axles for this application. And yes once the swap is properly completed you will be able to drive it like its a v-8 car as long as the engine and parts you use are good.
02-20-2013, 12:38 PM
#10 | | Registered User
Ok sounds like a lot but I already put a lot of money on the appearance and I don't wanna sell it so umma just upgrade it to a v8. That's all the questions I have now but if I get more later ill just message u cuz u know ur mustang stuff  thanks a lot
02-20-2013, 12:41 PM
#11 | | Registered User
Lol. That is all.
2003 Mach 1
02-20-2013, 12:42 PM
#12 | | Registered User
Your welcome. Also theres the exhuast. You will need to use a Cobra mid pipe and a GT catback, not a cobra catback. The cobra catback is designed around the cobra IRS which you will not have, a GT catback is the proper exhuast setup to use, stock or aftermarket as long as its for the GT. As well the cobra midpipe may be stock or aftermarket. And obviously Cobra air intake and cobra mass air will be needed but im guessing you already have that since you said you had what you needed to make it run.
+Engine mounts.
02-20-2013, 01:24 PM
#13 | | Registered User
I did a little looking around and it would seem I was wrong. I thought ford did away with the 7.5 rear end by 04 but they didnt. You will need a 8.8 rear end but I recomend one for a GT. Dont use the cobra IRS setup.
02-20-2013, 04:47 PM
#14 | | Registered User
Kk umma try to find a wrecked gt/cobra body to get parts from
02-20-2013, 04:54 PM
#15 | | Registered User
Junkyards and cars being parted out are a good source of parts.
02-20-2013, 05:08 PM
#16 | | Registered User
Hard to find a mustang that's wreck people snatch them
02-20-2013, 05:12 PM
#17 | | Registered User
Id be watching Ebay and Craigslist like a hawk.
02-20-2013, 06:04 PM
#18 | | Registered User
Only bad thing is its so hard to find a mustang that's not to bad cuz everyone takes them up quick
02-20-2013, 07:16 PM
#19 | | Registered User
Yea don't think one will be over 2k if its wrecked
