need answers quick! - Mustang Evolution
Old 02-20-2013, 04:18 PM   #1
shsfresh87's Avatar
Region: West Virgina
need answers quick!
Pypes off road shortie hpipe shouldn't need anything to bolt up to SLP LT headers right? It should just fit correct?
shsfresh87 is offline   Reply With Quote
Old 02-20-2013, 04:23 PM   #2
No. Shortie mid pipes are designed to bolt up to shortie headers not long tube headers. Whats more usually long tube headers require the same brand long tube header mid pipe to bolt on without modification.
DieselStang is offline   Reply With Quote
Old 02-20-2013, 04:26 PM   #3
Venomouz831's Avatar
Aren't short midpipes designed for longtubes
)02 Gt, Founder of WE2G
Old 02-20-2013, 04:27 PM   #4
06REDF1RE's Avatar
NOPE, shorty mid pipes are for long tube headers, while full length mid pipes are for shorty headers.
---------- Post added at 05:27 PM ---------- Previous post was at 05:26 PM ----------
Yes they are!
2004 GT Premium Package: mach 1 grille delete, 8" shorty antenna, CDC lightbar, borla stingers, UPR o/r x, Black chrome bumper inserts, redline tuning hood struts, white face gauges, raxiom smoked tail lights.
Born on 3/31/04
06REDF1RE is offline   Reply With Quote
Old 02-20-2013, 04:59 PM   #5
You guys cant be serious right now.. Yes short midpipes are for long tube headers. Shortie mid pipes are longer and for shortie headers. He said he had a hpipe for a shortie which is a long mid pipe and the answer is still the same, no shortie midpipes will not bolt onto long tube headers without being modified, end of story.
Old 02-20-2013, 05:01 PM   #6
BigB227's Avatar
I think the miscommunication is in the wording. A shorter mid pipe is what will bolt up to longtubes
BigB227 is offline   Reply With Quote
Old 02-20-2013, 05:06 PM   #7
Exactly correct. But a "shortie" mid pipe indicates that mid pipe is used for "shortie" headers and is a longer pipe.
Old 02-20-2013, 05:17 PM   #8
deadsp0t's Avatar
Seriously, a 'shortie' pipe refers to the length of the mid pipe itself, not the header. Bottom line.
That's unimpressive
Old 02-20-2013, 05:26 PM   #9
I disagree.. Exhuast manufactures laber their exhuast as per use with short tube headers or for long tube headers. This in my veiw means a "shortie" mid pipe is for use with short tube headers.
Old 02-20-2013, 05:34 PM   #10
deadsp0t's Avatar
Please post a link to a 'shortie H-Pipe' that mates to shortie headers, please.
That's unimpressive
Old 02-20-2013, 05:38 PM   #11
Furthermore. If his pypes mid pipe is indeed intended for use with LT header it still will most likely not fit without modification to SLP long tubes. Different exhuast manufactures of LT headers have different length. This is unlike aftermarket midpipes for shorttubes that are all designed to bolt onto the same stock exhuast manifold.
Old 02-20-2013, 05:38 PM   #12
Boomdizzle's Avatar
I've always heard LT midpipes to be called shorty midpipes and I used to be on a Mustang Exhaust forum for years. And yes, they will bolt right up if you already have the LT's. If not, you will need to get o2 sensor extensions I think or MIL's since they usually have 4 o2's from the factory.
Torque: It's like crack for your right foot
Boomdizzle is offline   Reply With Quote
Old 02-20-2013, 05:40 PM   #13
Ok ill prove my point.
Mid-Pipes (H-Pipes/Pro Chambers)
Notice MAC refers to its midpipes as for use with longtube headers or for use with stock manifolds.
Show me one manfucature that refers to its mid pipes for use with long tube headers a shortie mid pipe..
Old 02-20-2013, 05:42 PM   #14
Boomdizzle's Avatar
I think they would bolt up fine to any LT's. I know people that have AR LT's and BBK midpipes as an example. I would just normally buy a matching set so you know it will fit like a glove without any headaches.
---------- Post added at 07:42 PM ---------- Previous post was at 07:40 PM ----------
Mac is the only manufacturer that uses the same midpipe for LT's as shorties. I have had several MAC midpipes and the only difference between the shorty midpipe and the regular midpipe was that the regular one came with "flow tubes" that went from the midpipe to the shorty headers. The LT's took place of those "flow tubes" on the shorty midpipe.
Old 02-20-2013, 05:43 PM   #15
deadsp0t's Avatar
Wait, what.. don't see anything relevant here at all..
Anyways, OP, I believe you have the info you need! Hope all this... Doesn't confuse ya
That's unimpressive
Old 02-20-2013, 05:45 PM   #16
Boomdizzle's Avatar
http://www.americanmuscle.com/mac-sh...er-0509gt.html
Shorty midpipe that is for LT's only.
Old 02-20-2013, 05:46 PM   #17
I know that they are the same except for the flow tubes but they sell their equipment based on wether you need those flow tube by wether or not your using long or short tube headers.
Old 02-20-2013, 05:47 PM   #18
deadsp0t's Avatar
Americanmuscle advertises them as 'Shorty pipes'
http://www.americanmuscle.com/9904-mustang-hpipe.html
That's unimpressive
Old 02-20-2013, 05:54 PM   #19
MAC Ford Mustang GT 4.6L 2Valve & Cobra 4.6L 4Valve Off Road H-Pipe for MAC Long Tube Headers TF9699 Off-Raod H-Pipe for MAC Long Tube Headers Part #'s TF9603 or TF9625 (GT) & Part #'s TF9902 or TF9900 (Cobra). Our Off Road H-Pipe will...
AS PER USE WITH LONG TUBE HEADERS!
MAC Ford Mustang Cobra 4.6L V8 4Valve 1996-1998 2½" Aluminized Steel Off Road Pro Chamber to Stock Manifolds The MAC Patented Pro Chamber™ has made the current intermediate systems obsolete all together. Split (one each side)..
AS PER USE WITH STOCK MANIFOLDS. WHICH WE KNOW CAN BE REPLACED WITH SHORTYS.
---------- Post added at 06:51 PM ---------- Previous post was at 06:47 PM ----------
Wow American Muscle even has it *** backwards. And I say that because Ive been in the mustang scene even longer than american muscle.. lol
Eitherway they are still wrong. Just like how aftermarket companies who refer to ford 302's as being small blocks. Smallblock/Bigblock is chevy terms Ford has Familys FE/Windor/Modular ETC.
---------- Post added at 06:52 PM ---------- Previous post was at 06:51 PM ----------
Plus American Muscle is a distributor not a manufactuer.
---------- Post added at 06:54 PM ---------- Previous post was at 06:52 PM ----------
And yes you dont have to use one companys mid pipe just because your using their headers all im saying is dont expect to bolt on a different brand exhuast pipe to your long tube headers and expect it to fit without modification because it wont.
Old 02-20-2013, 06:08 PM   #20
06REDF1RE's Avatar
+10000000000000
Born on 3/31/04
Old 02-20-2013, 06:23 PM   #21
Ok well you guys can call it what you want but I'm still going to go by what the manfactuers say as they are the ones that make it..
Old 02-20-2013, 07:06 PM   #22
shsfresh87's Avatar
Thanks for the info. I didn't mean to start WWIII lol
Old 02-20-2013, 07:11 PM   #23
deadsp0t's Avatar
That's unimpressive
Old 02-20-2013, 07:13 PM   #24
Horseplay's Avatar
LOL
Low2v
Old 02-20-2013, 07:31 PM   #25
Ubnbit's Avatar
Originally Posted by Horseplay View Post
LOL
Bahahahahaha. It gets serious sometimes. It's just passionate people that are passionate about their cars and knowledge. Good thing is tomorrow, they will be able to agree passionate about something.
Old 02-20-2013, 08:43 PM   #26
BigB227's Avatar
+100000
Old 02-20-2013, 11:37 PM   #27
I agree to disagree about everything until I agree to it. lol!
Old 02-21-2013, 06:08 AM   #28
jjsg09's Avatar
Wow this got out of hand quick.
Old 02-21-2013, 03:58 PM   #29
Ubnbit's Avatar
Musta been a full moon yesterday. There were a couple other threads that got heated. Really heated.
03:18 AM
