99 GT theft light blinking and wont start - Mustang Evolution
Old 02-21-2013, 08:09 AM   #1
35th GT's Avatar
I drove it the other day just fine, now the theft light is blinking really fast when I try to turn it over.. It'll try to start but won't crank.. Help??
35th GT is offline   Reply With Quote
Old 02-21-2013, 08:18 AM   #2
Gera8712's Avatar
I had the same problem the other day.. First time in 7 yrs that I've owned her... I don't really know what fixed it since I try almost everything but I do remember I took the key off the ignition, shut the door and lock it them repeat the procedure backwards
Lamme know if it works for you!
Gera8712 is offline   Reply With Quote
Old 02-21-2013, 08:23 AM   #3
fomoco4life's Avatar
You guys probably need new batteries... get em tested for free at kragen... Id start there for sure
fomoco4life is online now   Reply With Quote
Old 02-21-2013, 08:28 AM   #4
35th GT's Avatar
The battery is fine
---------- Post added at 09:28 AM ---------- Previous post was at 09:26 AM ----------
I tried unhooking the battery, turning the key on an off rapidly etc. how do I unhook the theft system?
Old 02-21-2013, 08:36 AM   #5
Gera8712's Avatar
Originally Posted by 35th GT View Post
The battery is fine
I don't think you can disable that feature since is a module related deal unless you have a rotunda scan tool.. Try locking and unlocking the doors with the key on, I know it has something to do the order you did things(locked it first then shut the engine off then tried to get out with the doors being locked)
Old 02-21-2013, 09:03 AM   #6
35th GT's Avatar
Looks like ill be taking it to the dealership.. Nothing is working.. Lol thanks anyway guys
Old 02-21-2013, 09:51 AM   #7
Mile high JDF's Avatar
You probably just need a new key.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 02-21-2013, 10:06 AM   #8
35th GT's Avatar
Having it towed to the dealership soon.. Ill ask them about the key. Thanks
Old 02-21-2013, 10:29 AM   #9
Gera8712's Avatar
You should give it another try just keep messing with locking/unlocking and the key in the ignition it could save u a couple hundred dlls
Old 02-21-2013, 10:41 AM   #10
35th GT's Avatar
Got it running! I did what you said plus I turned the blinkers on etc lol that is stupid but it worked.. Thanks man
Old 02-21-2013, 12:50 PM   #11
tfalk's Avatar
If you have a tilt wheel, move it in the other direction... I had the same problem with my 99, there is a wiring harness that gets damaged after a while from moving the tilt wheel...
Mine would only start when the wheel was down.
99-122 Bright Atlantic Blue S281 S/C Convertible
11-025 Grabber Blue S302 Convertible
Saleen - Power in the hands of a fool!
tfalk is offline   Reply With Quote
Old 02-21-2013, 01:22 PM   #12
35th GT's Avatar
Lmao I think I even moved that before it finally started... Thanks man
03:49 AM
