Spoiler removal? - Mustang Evolution
Old 02-21-2013, 11:25 AM   #1
96smoke's Avatar
Spoiler removal?
Looking to go without the spoiler. But wanted to get you guys opinions on the best ways to plug the holes where the spoiler was? What're ways you guys have done it?
96smoke is offline   Reply With Quote
Old 02-21-2013, 11:27 AM   #2
chickengeorge's Avatar
This was pretty helpful to me.
chickengeorge is offline   Reply With Quote
Old 02-21-2013, 11:27 AM   #3
slow281
sixpac's Avatar
Region: Nebraska
On my 01 I used zinc plugs from the hardware store. They don't rust and paint easy if you want
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 02-21-2013, 11:33 AM   #4
TheNewKid's Avatar
I recently took the spoiler off my car... I went to Lowe's and grabbed 4 5/16 inch plugs and some silicon. Kinda rigged weird, but looks clean. Take the spoiler off, put the caps in, and silicon from the bottom to make it water tight. It doesnt mess your paint up. All i need to do is take some cleaner wax or something to the trunk lid, my spoiler left an ugly ring.
CAI, Off-road H-Pipes, 3.73's and a short throw. UDP and Tuner should be here any day....
TheNewKid is offline   Reply With Quote
Old 02-21-2013, 12:25 PM   #5
Mzilla's Avatar
I had my decklid holes filled and repainted
Mzilla is offline   Reply With Quote
Old 02-21-2013, 12:28 PM   #6
1996mustang's Avatar
Heres a pic of mine since we have the same body style
Old 02-21-2013, 01:36 PM   #7
Foxone's Avatar
If you do end up repainting like Im doing. Use Everglass short strand filler in the holes. Then glazing and prime. dont just pack bondo in the holes. Otherwise, the plug will do in a pinch and reversable in case you change your mind or sell the car.
Foxone is offline   Reply With Quote
Old 02-21-2013, 04:21 PM   #8
96smoke's Avatar
Did you plug yours?
Old 02-21-2013, 04:27 PM   #9
Rosco's Avatar
I used jb weld to fill the holes, then bondo body filler to smooth out the lid and get rid of pin holes. Then a self etching primer, primer, basecoat and then clearcoat. Got my tax return so ordering more paint since I wasn't able to do as many coats as I would like to. Use plastic plugs to see if you like it. Don't run with plastic plugs for months on end.
ID:	92146   Click image for larger version
1998 Bright Atlantic Cobra - 3:73's, BBK ls, Pro 5.0, 96 Cobra STB, Borla XR-1 Catback, Custom Catch Can, Spec clutch, MM Firewall adj, FRPP wires, RSD, Spoiler delete, 245/275 BF Goodrich g sports on chrome 95 cobra r's
1998 V6 Mustang : SOLD!
Rosco is offline   Reply With Quote
Old 02-21-2013, 08:08 PM   #10
Did you plug yours?
I used plugs on mine i may gill them in soon with fiberglass since our trunks are fiberglass
---------- Post added at 10:08 PM ---------- Previous post was at 10:06 PM ----------
Been running with plugs for a while now. No leaks no problems however i did use silicon to seal it a bit
Old 02-21-2013, 08:10 PM   #11
Mine came without a spoiler
ID:	92220   Click image for larger version
Old 02-21-2013, 08:46 PM   #12
slow281
sixpac's Avatar
Region: Nebraska
Because BULLITT!! Lol
2001 GT - True Blue
Old 02-21-2013, 08:52 PM   #13
Slow4V's Avatar
Old 02-23-2013, 08:09 AM   #14
goodwinta1's Avatar
Slow4V......is your whole car plasti'd?
goodwinta1 is offline   Reply With Quote
Old 02-23-2013, 09:30 AM   #15
v8pony's Avatar
Yes it is..I want to do it soooo bad, if I remember correctly it took him about 10 hours..he did an excellent job imo
2002 5spd GT
Feb 2013 Mustang of the Month
Old 02-23-2013, 10:39 AM   #16
goodwinta1's Avatar
Looks awesome for sure. I am behind the curve. Just now catching on to plasti dipping. I am going to try it out on my Explorer rims first.
Old 02-23-2013, 10:40 AM   #17
jjsg09's Avatar
Check this video out on plasti dipping your car.
Old 02-23-2013, 11:23 AM   #18
goodwinta1's Avatar
Awesome video. Thanks. Having trouble getting their site dipyourcar.com to come up for some reason but will definitely hit it up later.
Old 02-23-2013, 03:45 PM   #19
Foxone's Avatar
Just did mine today, beveled, filled with short strand fiberglass filler, then glazed and primed. I would use a good 2k primer vs self etching, self etching is more for bare metal protection.
ID:	92517   Click image for larger version
ID:	92519   Click image for larger version
Old 02-23-2013, 07:02 PM   #20
Slow4V's Avatar
« Lug locks | Gears. »
10:37 PM
