A slow build - Mustang Evolution
Old 02-21-2013, 11:48 AM   #1
TheNewKid's Avatar
A slow build
So Ive currently got my 3.73's, CAI, Offroad H pipe, and I've been wondering, outside of UDP and a tune... What else should I go for? I want to go to like 350-400 rwhp... Cams and heads? Any suggestions? Anyhting else other than cams/heads/UDP/tune? My buddy has an Ls1 440rwhp and I'm trying to build up to have a car that will compete at the strip with him... And if you could guess prices on what you list, shoot Or would putting a Vortech turbocharger work? It'd be a stock block/bottom end, but Ive been told tune it to low compression and run low boost...
CAI, Off-road H-Pipes, 3.73's and a short throw. UDP and Tuner should be here any day....
TheNewKid is offline   Reply With Quote
Old 02-21-2013, 11:52 AM   #2
Venomouz831's Avatar
What year? And budget
)02 Gt, Founder of WE2G
Old 02-21-2013, 11:53 AM   #3
TheNewKid's Avatar
2003, and budget will be slim.. I know its hard to build, but I guess try to be low :L
Old 02-21-2013, 11:55 AM   #4
Cams and heads will get you around 320. If you out a blower on it and have it around 8 psi you can be in in the 350-380 range with the the stock block.
Old 02-21-2013, 11:58 AM   #5
TheNewKid's Avatar
Your saying a blower after Cams and heads Ill be around 350-380? Or blower on stock block 350-380?
Old 02-21-2013, 11:59 AM   #6
A blower by itself with supporting mods will get you on that range. I've seen cams as heads on these cars as they produce less than 340
Old 02-21-2013, 12:02 PM   #7
TheNewKid's Avatar
Gotcha, Im trying to figure this out.. Cams/heads would run 1200... The blower would be 4000 ish. What other supporting mods would I need you think? injectors and such?
Old 02-21-2013, 12:04 PM   #8
Yea injectors, fuel pump, intercooled would be reccomended, exhaust, dyno tune
Old 02-21-2013, 12:05 PM   #9
TheNewKid's Avatar
Gotcha. FRom what I understand, the intercooler and fuel pump would come with the Vortech kit from AM. And to make sure its done right, Id go to a shop down the road and get them to put it on..
Old 02-21-2013, 12:06 PM   #10
If it comes with the kit that would be great. It just also depends on what you want out the car. Is it going to be a DD, track car or just a fast road car
Old 02-21-2013, 12:36 PM   #11
TheNewKid's Avatar
Its gonna be a combo, it is my DD but I'm gonna do stuff like 'test and tune' at local drag tracks with it
10:51 AM
