4.6L block question - Mustang Evolution
Old 02-21-2013, 11:50 PM   #1
4.6L block question
I have a quik question bout a 4.6L block i just picked up..basicly i have a 98gt with a spun rod bearing..i just picked up a short block 4.6L of a 2000 or 2001 crown vic..im pretty sure its a windsor block so im not worried bout the heads fitting..my question is will my timing cover and everything that bolts to it from my 98 would fit on this other block??? thanx in advance
RepumSN95 is offline   Reply With Quote
Old 02-21-2013, 11:52 PM   #2
Coreyw428's Avatar
Region: Arkansas
Yea as long as the block in your car was a winsor block
Coreyw428 is offline   Reply With Quote
Old 02-22-2013, 08:06 AM   #3
tonyd01gt's Avatar
4.6 block question
Originally Posted by Coreyw428 View Post
Yea as long as the block in your car was a Windsor block
How can you tell the different btw the 2 block?
tonyd01gt is offline   Reply With Quote
Old 02-22-2013, 05:09 PM   #4
Coreyw428's Avatar
Region: Arkansas
On the back of the block it will have a w stamped if it's a Windsor block, and you could count the number of bolts on the valve covers, if they match your good....
Old 02-22-2013, 07:59 PM   #5
Also my mustang is a vin "x" the x meaning windsor
Old 02-22-2013, 09:15 PM   #6
1996mustang's Avatar
Means your a 4.6l ie a gt
Old 03-02-2013, 10:21 AM   #7
mhobbs's Avatar
yep if they are same block just count valve cover bolts
mhobbs is offline   Reply With Quote
06:20 PM
