Seafoam - Mustang Evolution
Old 02-22-2013, 06:47 AM   #1
Silver Pony's Avatar
Seafoam
Yes or no? I have 140,000 miles on her? Will it really clean out the bad stuff? Thinking about doing it then changing the oil and the spark plugs all at the same time. She seems a little sluggish these days.
Silver Pony is offline   Reply With Quote
Old 02-22-2013, 06:50 AM   #2
Adogg's Avatar
Well if you do let me know how it goes I was thinking the same thing just afraid of it screwing something up lol
Don't hate....... appreciate
Old 02-22-2013, 06:50 AM   #3
Mfore33's Avatar
I've done the sea foam with good results. But I also just replaced my factory upstream o2 sensors and that made a big difference.
Old 02-22-2013, 06:52 AM   #4
Yeah, I'm afraid of messing something up too. I've only heard good things, but I'm still a little nervous about it.
Old 02-22-2013, 06:53 AM   #5
Adogg's Avatar
This might be a stupid question but how does it really work?
Old 02-22-2013, 06:57 AM   #6
I'm thinking that's got a lot to do with the performance right now. I need to go in and change the little maintenance things.
---------- Post added at 07:57 AM ---------- Previous post was at 07:55 AM ----------
The videos I've watched looks easy. You put some in the gas tank, in the engine and run it through a vacuum line. Check out YouTube.
Old 02-22-2013, 06:59 AM   #7
Mfore33's Avatar
Well the chemicals eat away at the carbon deposits in the intake and clean fuel lines when added to gas. I've run full bottle in tank as well as done the 1/3 in tank 1/3 in crankcase and 1/3 into the vacuum line. Makes car smoke and sputter so you need to be able to work throttle cable so it won't die on you. Then after it burns off I drove for about 50 miles and got oil change.
Old 02-22-2013, 06:59 AM   #8
Adogg's Avatar
Alright thanks man and yea very good idea to do the sparks and oil. I did that to my car and I got new spark plug wires and the car is running like a beast
Old 02-22-2013, 07:01 AM   #9
Mfore33's Avatar
My car has 180000 on it and when I put new o2 sensors in it felt like I got some power back. Throttle response was better and the mild gas smell went away. I wasn't throwing any codes I just think the sensors were worn out and reacted slowly to changes in exhaust causing rough idle and bad mpg.
Old 02-22-2013, 07:06 AM   #10
What exhaust are you running? I have a bassani catted xpipe with flowmaster and I have a little stink to it now. I've had the car for about 1 1/2 years and haven't changed anything except the oil. I think I've put about 20,000 miles since I've had it..I figured it's about time to change the plugs so I thought I would do it all at the same time.
Old 02-22-2013, 07:09 AM   #11
Mfore33's Avatar
I just have stock car except flowmasters. I bought the car new off the showroom floor. One owner baby!
Old 02-22-2013, 07:09 AM   #12
Adogg's Avatar
I only a have one set if o2 censors right after the headers I think and I have no cats do you think they would be worth replacing them?
Old 02-22-2013, 07:11 AM   #13
Mfore33's Avatar
You need to make sure if you think you have no cats. Are you showing any check engine light? If you don't have cats then what you have might be mil eliminators.
Old 02-22-2013, 07:14 AM   #14
Adogg's Avatar
Lol I know I have no cats I have an o/r hpipe I mean I think I only have one set of o2 censors and they are right after the headers. Sorry for the confusion
Old 02-22-2013, 07:16 AM   #15
Mfore33's Avatar
Well I would think if the car is still using the sensors and the sensors are old like mine were it might not hurt to replace them. I got mine from rockauto for 25 each. Oem Ntk from Japan.
Old 02-22-2013, 07:17 AM   #16
Adogg's Avatar
Alright that sounds good. They aren't hard to replace are they?
Old 02-22-2013, 07:20 AM   #17
Mfore33's Avatar
Well make sure your car is cool. Was very tight on right side. It took bending a wrench and a crowbar to get room on the right side.
Old 02-22-2013, 07:24 AM   #18
Adogg's Avatar
Damn really? Thanks for the help man
Old 02-22-2013, 07:46 AM   #19
Nice
Old 02-22-2013, 09:16 AM   #20
1lowGT's Avatar
Did you install the h pipe yourself? I would run some seafoam through it, change the plugs, tranny oil, flush radiator. Just a good clean up.
Old 02-22-2013, 09:40 AM   #21
Adogg's Avatar
Are you asking me if I installed my h pipe?
Old 02-22-2013, 02:48 PM   #22
98GTCONV's Avatar
I say do it, I did it at 154,000. Can't really tell performance wise but I mean its $9.99...it certainly doesn't hurt to do it. Only this is, make sure when your pouring it into a vacuum line that a buddy is on the gas and you pour it very very slow. Every other step is pretty easy.
98GTCONV is offline   Reply With Quote
Old 02-22-2013, 07:12 PM   #23
I think I am. Like you said it won't hurt. Thanks guys
Old 02-22-2013, 07:49 PM   #24
nickysixx's Avatar
Lol seafoam is diluted kerosene.
____________________________________________
1957 Buick Special Estate Wagon
1996 Mustang GT (sold)
1997 Mustang V6 (sold)
2002 Jeep Grand Cherokee Laredo (sold)
2007 Jeep Grand Cherokee
nickysixx is offline   Reply With Quote
Old 02-22-2013, 09:23 PM   #25
1lowGT's Avatar
Uh yes.
Old 02-23-2013, 08:34 AM   #26
Adogg's Avatar
Uh yes.
Oooo well no I had it welded on for me by an exhaust shop
Old 02-23-2013, 08:29 PM   #27
1lowGT's Avatar
Did you buy the whole catback?
Old 02-23-2013, 08:46 PM   #28
Adogg's Avatar
No not really worth buying a cat back I just got the two 10 series used the stock tail pipes cause they're in good condition and then got the h pipe put on
Old 02-23-2013, 10:50 PM   #29
BigB227's Avatar
You only have two o2 sensors because only the two right after the exhaust manifold matter to the computer. The two After cats or downstream ones are for telling the efficiency of the cats, which if you have none they are useless
BigB227 is offline   Reply With Quote
Old 02-23-2013, 11:53 PM   #30
1lowGT's Avatar
Well that's true. But opening up the exhaust from factory sizes like piping to 2.5 inch to 3 inch tips. Idk what the stock size is
Old 02-24-2013, 04:25 PM   #31
escottcarp's Avatar
Seafoam is good stuff. My wife's minivan had a P0303 miss. I put two cans of Seafoam in the gas tank when she had about two gallons of gas in it. Ran it about 30 miles and put two gallons of gas and one can of Seafoam. No more miss, no codes, much better power and acceleration, better idle, and better gas mileage. It worked great for me!!
escottcarp is offline   Reply With Quote
11:59 AM
