Rpm problem - Mustang Evolution
Old 02-22-2013, 09:18 AM   #1
35th GT's Avatar
Rpm problem
The car idols fine and it drives fine this is a 99 GT 5 speed.. When you're slowing down in it the Rpms jump from 1k to almost 0 sometimes it dies and some it doesn't.. It only does this when you're driving and put your foot on the clutch to start slowing down.. Any advice?
35th GT is offline   Reply With Quote
Old 02-22-2013, 09:38 AM   #2
tonyd01gt's Avatar
Hi, check all your vacuum lines. also check the TPS, IAC. You should be able to clean the IAC.Check for carbon build up on it
tonyd01gt is offline   Reply With Quote
Old 02-22-2013, 09:40 AM   #3
35th GT's Avatar
Thanks tony.. Where can I find the line? This is my first muscle car, I just got it 3 days ago I've always owned trucks.
Old 02-22-2013, 10:19 AM   #4
1996v6stang's Avatar
Congrats on ur first stang, hope she quits bein a pita lmao
1996v6stang is offline   Reply With Quote
Old 02-22-2013, 11:10 AM   #5
35th GT's Avatar
I know that's right.. It's got tons of power.. it has a steda tri axe shifter, F-1 Clutch, 373 gears, intake, Pulleys, Mac Headers, Slp loud mouth exhaust, drilled rotors, 75mm throttle body, 42lb injectors, supercharged but the charger is burnt up, still running the inter cooler with a air filter lol
Old 02-22-2013, 12:19 PM   #6
Mfore33's Avatar
+1 on the iac
Old 02-22-2013, 12:26 PM   #7
jjsg09's Avatar
This is it. Take it off clean it you should be golden.
Old 02-22-2013, 12:39 PM   #8
35th GT's Avatar
Thank you very much! I'm going to try that in a few
---------- Post added at 12:39 PM ---------- Previous post was at 12:38 PM ----------
Originally Posted by Mfore33 View Post
+1 on the iac
I see a lot of y'all post +1.. I'm new to this site.. What's that mean?
Old 02-22-2013, 01:24 PM   #9
v8pony's Avatar
+1 essentially means "I agree"
2002 5spd GT
Feb 2013 Mustang of the Month
Old 02-22-2013, 01:27 PM   #10
35th GT's Avatar
Ok thanks
Old 02-22-2013, 01:37 PM   #11
bingo the IAC (idle bypass valve) acts up more so in the cold weather as it gets older. Clean it good and try it, if it acts up but its better then replace it, if its good after cleaning go about your driving.
Old 02-22-2013, 01:45 PM   #12
35th GT's Avatar
Thank you
Old 02-22-2013, 05:18 PM   #13
Slow4V's Avatar
IAC is bad
Old 02-22-2013, 05:51 PM   #14
35th GT's Avatar
Originally Posted by Slow4V View Post
IAC is bad
Ok.. It's got a hose running from it to my supercharger pipe.. Could that be a problem?
Old 02-22-2013, 10:21 PM   #15
1996mustang's Avatar
No the iac itself would be the issue on this one yhe hose is where it gets air from to go intp the intake to keep it at idle
Old 02-22-2013, 10:26 PM   #16
35th GT's Avatar
Ok.. Will give that a shot thanks
Old 02-23-2013, 09:14 AM   #17
tonyd01gt's Avatar
Rpm problem
Hi, sorry i did not post pics.Did you get problem solved?
Old 02-23-2013, 11:17 AM   #18
35th GT's Avatar
Not yet.. I'm being told its 3 different things, I'm checking the throttle position sensor, iac valve and other lines... I may just replace them all?
Old 02-23-2013, 02:28 PM   #19
tonyd01gt's Avatar
hi, first check all the rubber hose/lines for any cracks ,holes. etc Then take off the IAC. Clean the inside with a tooth brush. i used brake cleaner to clean mine with. wipe off as much film ,carbon as you can. let it air dry or blow off with air tank. i would not recommend just buying parts. until you first find/ id the issue/problem . can you post pics of your engine?
Old 02-23-2013, 02:30 PM   #20
35th GT's Avatar
I have one of the engine on my profile
Old 02-23-2013, 02:37 PM   #21
tonyd01gt's Avatar
Rpm problem
Attachment 92299
This is the IAC .Should have 2 bolts and a 1electrical plug, gasket.
Old 02-23-2013, 10:49 PM   #22
35th GT's Avatar
Got it fixed.. It was a line that plugs into the thing next to the IAC.. It was out a little.. I went through and looked at the whole motor, I guess it came out when I gunned the car the other day .. Thanks man for helping me and thanks to everyone else!
Old 02-24-2013, 11:04 AM   #23
tonyd01gt's Avatar
OK, glad i could help.
09:25 PM
