IRS Swap - Mustang Evolution
Old 02-23-2013, 08:06 PM   #1
Mile high JDF's Avatar
So I'm going to be doing an IRS swap with a guy from a local forum and I was wondering how straightforward of a swap it is. He has an 03 Cobra and I've heard that I will need to swap a flange or something like that? If anybody has some insight on doing this, that would be great.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 03-04-2013, 08:44 PM   #2
Top stang's Avatar
Let me know how it goes cuz I want to do the same
Top stang is offline   Reply With Quote
Old 03-04-2013, 09:03 PM   #3
I will. I'm doing it this weekend so it wont be too long. The swap seems pretty straightforward.
Old 03-04-2013, 09:03 PM   #4
1996mustang's Avatar
I believe he will need the cradle for the irs as well as the shocks/struts that go along the rear end ofcouse which isnt a solid rear end but a diff with cv axles and upper and lower control arms. Im sure ill be corrected if incorrect and you will get your answer soon enough but its not a bolt on and go from what i know
Old 03-04-2013, 09:10 PM   #5
From all the write-ups I've seen it bolts right up. The only problem is with 03/04 rear ends you need a special u-joint that fits both flanges.
Old 03-05-2013, 11:05 AM   #6
1lowGT's Avatar
So why are you doing this just curious?
Old 03-05-2013, 11:09 AM   #7
Slow4V's Avatar
He road races
Old 03-05-2013, 11:24 AM   #8
Originally Posted by Slow4V View Post
He road races
+1 it's a better handling suspension for racing than a live axle and should allow for me to tune it towards my driving style.
Old 03-05-2013, 11:52 AM   #9
1lowGT's Avatar
I see i didnt know if you had a purpose or not
Old 03-05-2013, 11:59 AM   #10
Well it its nice getting the look of the Cobra exhaust.
Old 03-05-2013, 12:00 PM   #11
1lowGT's Avatar
+1 gotta love that, what exhaust you gonna go with?
Old 03-05-2013, 12:04 PM   #12
The guy I'm trading with currently has the Magnaflow catback with Bassani tips. If I don't like it then I'll buy some Bola Stinger mufflers.
Old 03-05-2013, 12:06 PM   #13
1lowGT's Avatar
Nice. Good luck, post a pic of it afterwards.
Old 03-05-2013, 12:11 PM   #14
I will definitely do that. I'm just trying to decide if I should cut off a coil or not because he has the stock springs still.
Old 03-05-2013, 12:14 PM   #15
1lowGT's Avatar
I see, yeah i would go ahead and do that or wait after you get it installed and then drop it agin. i know the sra are easy to drop real fast. no experience with the irs
Old 03-05-2013, 12:30 PM   #16
Me neither. I'll probably just leave it and wait to find a good deal on some rear springs.
Old 03-05-2013, 12:40 PM   #17
1lowGT's Avatar
Yeah but itlll be hard to find just rear springs
Old 03-05-2013, 01:43 PM   #18
I've just got to look for a guy who did a SRA swap and doesn't need his rear springs.
Old 03-10-2013, 12:10 PM   #19
Well yesterday was the day we had planned on trading but Colorado had a different idea. We ended up getting a nice blizzard so we cancelled and are trying to find another day to do it.
Old 03-10-2013, 12:16 PM   #20
You will need the irs assembly. All mounting bolts plus the rear mount assembly (bolts to where your quad shocks are currently). Shocks and springs plus shock bolts. You will also need to swap pinion flanges or driveshaft end joints (i swapped pinion flanges as the cobra comes with a much stronger setup and I wanted to keep it).
I've done a few of these so feel free to ask any questions.
Old 03-10-2013, 12:30 PM   #21
Awesome thanks. I'm just going to swap u-joints because I don't want to go through the process of setting my pinion bearing pre-load.
Old 03-10-2013, 12:33 PM   #22
That will leave you with the stronger setup too. Smart man.
Old 03-10-2013, 01:15 PM   #23
I think I got the better end of the deal in general.
Old 03-25-2013, 02:53 PM   #24
Well I figured I would give an update, since we had to cancel a couple weeks ago because of snow, we're gonna try for this Saturday. Unfortunately he wizened up to the fact that he would be getting the weaker flange so he ordered the differential side of the flange. I should be picking up the drive shaft side tomorrow.
Old 03-25-2013, 04:00 PM   #25
1lowGT's Avatar
Wgat gears are in the IRS
Old 03-25-2013, 04:06 PM   #26
3.55s
Old 03-25-2013, 04:06 PM   #27
1lowGT's Avatar
What's in yours?
Old 03-25-2013, 04:09 PM   #28
3.55s as well
Old 03-25-2013, 04:27 PM   #29
1lowGT's Avatar
Dang no upgrade then
Old 03-25-2013, 04:30 PM   #30
Well I get a 31 spline rear diff with carbon clutches, that's a good enough upgrade for me. I want to keep the 3.55s because I'm already almost hitting 5th on the straight at my local track.
Old 03-25-2013, 04:31 PM   #31
1lowGT's Avatar
I guess that's good then
Old 03-25-2013, 04:50 PM   #32
Yeah. If I had a different tranny then I would think about a steeper gear.
Old 03-25-2013, 06:48 PM   #33
1lowGT's Avatar
You auto or manual?
---------- Post added at 07:48 PM ---------- Previous post was at 07:48 PM ----------
Never mind lol
Old 03-30-2013, 09:03 PM   #34
Well it's been one hell of a day, we got everything swapped thankfully but ran into all sorts of snags. Took about 10hours by the time I locked up the shop and headed home. The exhaust sounds great and the suspension is definitely smoother. I'll get some before and after pictures tomorrow after I clean it.
Old 03-31-2013, 11:52 AM   #35
Before
After.
» Members Mustangs
98 V6
bmabbott
Sally
JR1952
Add your Mustang
09:18 PM
