Led Tail light bulbs - Mustang Evolution
Old 02-24-2013, 01:15 AM   #1
GP3GT's Avatar
Has anyone ever swapped out their tail light bulbs for led ones? I plan on tinting my tails and wanted to know if I can just straight swap them out or if I would need anything else since their my turn signal flasher lights as well..
95 Camaro- Sold
99 Camaro Z28- Sold
99 Mustang GT- DD
GP3GT is offline   Reply With Quote
Old 02-24-2013, 01:15 AM   #2
Slow4V's Avatar
Easy .. Twist and replace
Old 02-24-2013, 01:45 AM   #3
Gera8712's Avatar
I've always thought you had to use resistors between flasher and light bulb..
Gera8712 is offline   Reply With Quote
Old 02-24-2013, 02:11 AM   #4
GP3GT's Avatar
Yeah I've heard you might need something else as well. But I wanted to see if anyone has done this to their tail light bulbs yet
95 Camaro- Sold
99 Camaro Z28- Sold
99 Mustang GT- DD
Old 02-24-2013, 03:09 AM   #5
Venomouz831's Avatar
So they would be just led bulbs or is it like a kit
)02 Gt, Founder of WE2G
Old 02-24-2013, 09:56 AM   #6
Gera8712's Avatar
They're just led light bulbs but since LEDs are not loads to the flasher, flasher it's gonna think you have a burn light bulb
Old 02-24-2013, 10:42 AM   #7
Boomdizzle's Avatar
I put them in my fox body for awhile, I don't think you're going to get the look you want with them. The housings need reflected light for them to work and the LED's focus all of their light straight out the back. Your lights end up looking like 3 little circle lights instead of the big taillight sections. I almost got rear-ended a few times also when the sun was beating down on my taillights and no one could see the lights even come on.
Torque: It's like crack for your right foot
Boomdizzle is offline   Reply With Quote
Old 02-24-2013, 11:10 AM   #8
Gera8712's Avatar
Good point got there man!
Don't they also make a diff design where you can also have LEDs on the side of the light bulb not just the top, that might help a lil
Did u have to use anything else besides the lightbulbs tho?
Old 02-24-2013, 03:00 PM   #9
Mfore33's Avatar
Ddm tuning has some led lights. If you get some get the ones with multiple LEDs on the sides and all over
Old 02-24-2013, 03:27 PM   #10
GP3GT's Avatar
Like those? If I get some like that I wouldn't need anything else? Or since they're flashers would I need resistors as well?
95 Camaro- Sold
99 Camaro Z28- Sold
99 Mustang GT- DD
Old 02-24-2013, 05:08 PM   #11
Mzilla's Avatar
I had installed red LED tail lamp bulbs an yes it looked like three dot. The LED bulbs I had also had LED's on the back to illuminate the reflector inside the lens. Yes it looked cool but the illumination was nearly half. You also are suppose to install Red LED's on red lens not white on red. I installed the slyvania super white standard halogen bulbs to prevent from being rear ended.
ID:	92661   Click image for larger version
ID:	92667   Click image for larger version
Mzilla is offline   Reply With Quote
Old 02-24-2013, 06:33 PM   #12
jdavis96gt's Avatar
Region: West Virgina
Perfect timing. My vinyl tint for my taillights came yesterday and I was needing something brighter. I was thinking sylvania bulbs.
---------- Post added at 07:33 PM ---------- Previous post was at 07:29 PM ----------
When I did my dash lights, I tried blue with the factory blue film but wasn't bright. So I went with white less, with the blue film, its a lot brighter.
So I would've guessed the white on red would be brighter.
06:26 PM
