Axleback mufflers? - Mustang Evolution
Old 02-24-2013, 12:43 PM   #1
Tanker2012's Avatar
Axleback mufflers?
When I purchased my '97 GT it had BBK x-pipe mids without cats, no mufflers, and everything else was stock. I am planning on making the thing breath better overall by adding PI heads, stage 1 cams, new manifold, new plenum and throttle body as well as a new CAI and mass air. Most likely adding some short BBK headers as well. The car sounds great and is quick but with all of these upgrades I'm concerned about back pressure. I will get this thing dynotuned and handheld tuned as I go but I want to make sure I am getting enough back pressure in the heads. What do you guys think, do I need high flow mufflers and tips for maximum hp?
Tanker2012 is offline   Reply With Quote
Old 02-24-2013, 01:37 PM   #2
Mile high JDF's Avatar
I'm the goal of an exhaust is to get those exhaust gasses out and away from the engine as quickly as possible. Back pressure hinders your motor because it causes the engine to work harder at forcing those exhaust gasses out. The trick is to gain exhaust velocity.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 02-24-2013, 01:43 PM   #3
Tanker2012's Avatar
I guess what I am asking is that if anyone has had experience without cat/axle back exhaust components being installed. I agree, it's not so much a question of back pressure as it is between volume and velocity of exhaust evacuation. Without high flow mufflers and tips will the x-pipes provide enough velocity due to their diameter. Thanks for the feedback.
Old 02-24-2013, 02:17 PM   #4
Is your catback the stock 2 1/4" piping?
Old 02-24-2013, 02:18 PM   #5
Tanker2012's Avatar
The x-pipe does not have cats (it's off road). There's stock manifold and then the BBK x-pipes; that's the only exhaust plumbing on the car.
Old 02-24-2013, 02:31 PM   #6
A catback exhaust is what comes after the midpipe an goes over the axles. If it's still stock other than removing the mufflers then I would recommend upgrading to some 2.5" pipes because that's what size your BBK X-pipe is. I don't know how much exhaust flow you will pick up with it, but it should help a little bit.
Old 02-24-2013, 02:37 PM   #7
Tanker2012's Avatar
So, are you recommending I add an aftermarket catback setup that's 2.5", same as the BBK mid pipes? I could just take straight 2.5" pipe back over the axle and add tips. It's pretty raspy right now, which is fine, but I was concerned that stopping the exhaust plumbing at the x-pipes might not help with power. Thanks, again for your feedback.
Old 02-24-2013, 02:48 PM   #8
Yes that should work.
Old 02-24-2013, 02:50 PM   #9
Tanker2012's Avatar
Cool, I think I am going to just bring the 2.5" tubing back over the axle and dump it under the bumpers. To be honest, I like the hidden exhaust. Thanks.
Old 02-24-2013, 02:51 PM   #10
That will be pretty sweet
Old 02-24-2013, 02:53 PM   #11
Tanker2012's Avatar
It sounds great and it looks clean, I think that adding the tubing will help especially with the in-flow upgrades to get the engine to breath better. These mod 8s are different. First OHC engine I've owned and worked on.
Thanks again.
Old 02-24-2013, 02:54 PM   #12
Yeah no problem man, good luck
01:00 AM
