Pulleys - Mustang Evolution
Old 02-25-2013, 11:13 AM   #1
Nitrous02gt's Avatar
Pulleys
Anyone have any advice on a pulley set? I just got SR pulleys and someone said they will mess up my water or oil pump... :/ anyone have anything that will help me?
Nitrous02gt is offline   Reply With Quote
Old 02-25-2013, 11:15 AM   #2
you generally spin everything slower when you run pulleys, most only have issues with the alternator pulley if they dont put a smaller one back on to speed it back up. This is usually only an issue if they have a system in the car and you are sitting around near idle.
I never had any issues on my 01V6 with a crank pulley swap (25% slower)
Old 02-25-2013, 01:06 PM   #3
Lorraine's driver
ab_mach1's Avatar
I've heard that as well with the oil pumps used on the Mach 1 engines. I'm not planning to ever run with under drive pulleys, but if you do, at least use the Steeda set. Supposedly they worked with Ford on designing them. Maybe they were able to create something that doesn't effect harmonic balance..?
Instagram: @ab_mach1
Old 02-25-2013, 01:11 PM   #4
tonyd01gt's Avatar
Hi, i never had any issue with my UDP.Have them on all my cars.
tonyd01gt is offline   Reply With Quote
Old 02-25-2013, 01:24 PM   #5
Lorraine's driver
ab_mach1's Avatar
It could be something with Mach engines and the oil pumps eledgedly being weak. But, I will say I have never heard that with the SOHC 4.6L engines. The only thing I've heard is that you should put stock pulley's back on if you go forced induction.
Old 02-27-2013, 09:32 PM   #6
What brand do you use on your gt?
Old 02-28-2013, 06:45 AM   #7
Uhh taken's Avatar
Go with steeda with the built in balancer, don't wanna reuse your old one.
Uhh taken is offline   Reply With Quote
Old 02-28-2013, 06:55 AM   #8
It just sucks because I bought the stack racing pulleys from AM :/ will they take it back so I can get the other brand?
Old 02-28-2013, 08:05 AM   #9
jdavis96gt's Avatar
Region: West Virgina
They prob will if u buy the other set from them. Steeda is going to be more expensive, so more money for them. AM always tries to make us happy. Post them question in their section or call them.
Old 02-28-2013, 11:05 AM   #10
tonyd01gt's Avatar
Pulley
plus# 1 on the steeda.
10:43 AM
