98gt swap to 351w - Mustang Evolution
Old 02-25-2013, 06:24 PM   #1
RecklessRichy's Avatar
98gt swap to 351w
I have a 98gt and I want to swap a 351w in it. I need to know what I'm going to need. I already bought adjustable coil overs and a aftermarket kmember and camber plates for the suspension. I plan on getting a t56 transmission for the 351w too so I need to know if I will be able to put that on. If anyone can help please and thank you.
RecklessRichy is offline   Reply With Quote
Old 02-25-2013, 10:54 PM   #2
1996mustang's Avatar
Are u running carbed or efi standalone system? Putting a 351w isnt a big issue im sure u can use the mounts from a 302 essentially to sit the motor in the k member. However depends on what u run carbbed with high flow rails and adapter to fit the intake manifold u will use with carb. As for stand alone it speaks for itself really. But im also curious as to this since i have wanted to do a 427 cobra jet in mine maybe one day i get crazy enough to attempt it lol
Old 02-26-2013, 06:52 AM   #3
Yeah So far I plan on running it carbed, do you know If it will mount up to a t56?
Old 02-26-2013, 03:10 PM   #4
housing may differ from it, i would go on a limb to say if you use the housing from a t5 whichi bolts up however you will need a different backing plate, maybe a home made one if anything.
08:33 AM
