throw out bearing - Mustang Evolution
Old 02-26-2013, 04:36 PM   #1
02StangGT's Avatar
Does anyone know a reason my throw out bearing would keep going out in my 02 gt
02StangGT is offline   Reply With Quote
Old 02-26-2013, 04:46 PM   #2
Mile high JDF's Avatar
It's pretty common for the aftermarket ones to wear out quickly. It could be that your TOB is resting on the pressure plate fingers, those will cause it to wear out prematurely as well.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 02-26-2013, 05:04 PM   #3
zinc_yellow's Avatar
Region: New Mexico
Mines wore out too. I ordered a ford racing throw our and pilot bearing yesterday. I heard aftermarket ones don't last long, wear out, and start chattering
zinc_yellow is offline   Reply With Quote
Old 02-26-2013, 05:12 PM   #4
02StangGT's Avatar
So is there anyway to fix it? What is the best brarinf I heard the ford racing is good
Old 02-26-2013, 05:55 PM   #5
Slow4V's Avatar
If your replacing it do your whole clutch ..
Ford Racing is the best
Old 02-26-2013, 06:05 PM   #6
goodwinta1's Avatar
I agree. Do the entire clutch and use the Ford Racing Bearings (throw out and pilot)
goodwinta1 is offline   Reply With Quote
Old 02-26-2013, 06:09 PM   #7
You can start out by trying the TOB free-play mod (Azure wrote a good write-up on it) see if that works at least for the time being.
Old 02-26-2013, 06:48 PM   #8
Region: New Mexico
Not trying to Hijack the thread but What's the best clutch for a dd
Old 02-26-2013, 06:51 PM   #9
Depends completely on what your plans in the near future for the car and your ultimate goal.
Old 02-26-2013, 06:53 PM   #10
Xtrosity's Avatar
I would go with a stage 1 clutch. I put an exedy stage 2 in my daily and stop and go traffic blows.
Xtrosity is offline   Reply With Quote
Old 02-26-2013, 06:55 PM   #11
Region: New Mexico
I'm going into college and I'm not going to be throwing that much money into the engine yet.. It's still stock besides a catback. The clutch I have now seems real stiff compared to other manuals I've driven but it's had this clutch on since I bought it
Old 02-26-2013, 06:57 PM   #12
nickysixx's Avatar
+10000 i had spec stage 3... I had to go down to a stage 2
____________________________________________
1957 Buick Special Estate Wagon
1996 Mustang GT (sold)
1997 Mustang V6 (sold)
2002 Jeep Grand Cherokee Laredo (sold)
2007 Jeep Grand Cherokee
nickysixx is offline   Reply With Quote
Old 02-26-2013, 07:02 PM   #13
Region: New Mexico
Alright thanks. Stage 1 it is. I'll stop derailing the thread now
Old 02-27-2013, 12:14 PM   #14
Region: New Mexico
My two bearings arrived now its time to pull the transmission
Old 02-27-2013, 03:01 PM   #15
Foxone's Avatar
Youll find the stiff pedal to be more about the lack of grease on the splines where everything slides, definetly go with the Ford Racing stuff.
Foxone is offline   Reply With Quote
Old 03-01-2013, 10:21 PM   #16
Region: New Mexico
Started removing the starter today to get the transmission off and the hidden starter bolt is ridiculous to get off.
Old 03-01-2013, 11:15 PM   #17
Kstangs2002's Avatar
Good luck ive been wanting to replace mine too but i wanted to do it my self just dont know how hard it is let us know
Kstangs2002 is offline   Reply With Quote
Old 03-01-2013, 11:32 PM   #18
1996v6stang's Avatar
It aint hard. Ittl be a little harder if u have a 3650 compared to a t45 tho 3650 u have to pull the tranny and a bellhousing as a whole. T45 u can just un bolt the 4 from the bellhousing and pull the tranny. I have done 3 or 4 clutches myself.
1996v6stang is offline   Reply With Quote
Old 03-02-2013, 01:35 AM   #19
02StangGT's Avatar
The starter bolt sucks! Leave it out when you finally get it. Trust me it saves a lot of time
Old 03-02-2013, 05:11 AM   #20
CrimsonGT's Avatar
If someone would make a write up for swapping the clutch on the 3650 they would be my hero
CrimsonGT is offline   Reply With Quote
Old 03-02-2013, 07:45 AM   #21
Slow4V's Avatar
I will once i do my clutch
---------- Post added at 08:45 AM ---------- Previous post was at 08:44 AM ----------
I recommend alot of extensions , and swivel to get to start bolts
( go from front and work your way under or let the motor mount )
Old 03-02-2013, 08:29 AM   #22
goodwinta1's Avatar
5-Speed Swap Instructions
This is a write-up on an auto to manual swap but the removal of the trans is almost identical, and the installation of the manual (other than the pedal part) is golden. Check it out.
Good luck and let us know how it goes when you tackle it.
Old 03-02-2013, 08:30 AM   #23
Yep bout 2 ft of exstensions and a swivel haha
Old 03-02-2013, 08:32 AM   #24
goodwinta1's Avatar
I thought I was going to be doing my clutch but as it turned out the whine was coming from my differential. That isn't a job I will be trying to tackle on my own.
Old 03-02-2013, 09:10 AM   #25
Region: New Mexico
Going back into my shop now to tackle the exhaust bolt I have left and the hidden starter bolt.. Wish me luck!!
Old 03-02-2013, 09:47 AM   #26
Good luck dude! It isnt hard, u will be fine.
06:03 PM
