Brake dust prevention? - Mustang Evolution
Old 02-27-2013, 10:29 AM   #1
ryoung1219's Avatar
Does anyone have any tips for keeping break dust off of your wheels? I have the stock chrome wheels on my 2004 mustang gt and the break dust is so bad Im considering buying black wheels instead. I even got my break pads changed and was told that the new pads
caused little break dust but that's obviously not the case.
ryoung1219 is offline   Reply With Quote
Old 02-27-2013, 11:06 AM   #2
wheelman's Avatar
Ceramic pads, caliper covers and wax your wheels.
wheelman is offline   Reply With Quote
Old 02-27-2013, 11:16 AM   #3
ryoung1219's Avatar
Ok thanks I appreciate that.
Old 02-27-2013, 01:38 PM   #4
d_1212's Avatar
What if the damage is already done is there a good way to clean it? I tried grinding mine off but it was such a hassle.
d_1212 is offline   Reply With Quote
Old 02-27-2013, 01:50 PM   #5
jdavis96gt's Avatar
Region: West Virgina
Brake cleaner
Old 02-27-2013, 02:04 PM   #6
DaBluedude's Avatar
Black wheels don't help. I wear break dust like a champ haha. Best advice I can give is to use a thick sealant on the rims and to wax regularly.
2003 Mach 1
Old 02-27-2013, 07:26 PM   #7
jjsg09's Avatar
I had this same problem and I bought some expensive ceramic pads and it really cut it down. I got to a point where I was wiping down my rims about every other day before I got the better pads.
Old 02-27-2013, 09:46 PM   #8
02mineralgreygt's Avatar
Ceramic brake pads was one of the best things I have done to solve this problem as well. I would recommend you changing your brakes pads to ceramics and you should notice a big difference too.
02mineralgreygt is offline   Reply With Quote
Old 02-29-2016, 04:32 PM   #9
Brake dust
I've had similar problems with Mercedes and BMWs due to what I think is softer metal on the pads. They have great stopping power, but the dust accumulation is very bad.
reflections is offline   Reply With Quote
Old 03-04-2016, 05:08 AM   #10
fenixignition's Avatar
my dads bmw is horrendous with brake dust. even aftermarket "gold" box pads. idk if they apply more pressure to the pads or what.
but i use wagner thermoquiet semi metallics up front and thermoquiet ceramic in the rear. the brake dust is actually quite minimal.
what brand and type of pads do you all use?
also armor all makes a spray that you can put on your rims to prevent brake dust from building up. but for the cost of using that every month or two, you might as well just use a synthetic wax.
2002 GT 5sp. 16x,xxx miles
Old 03-04-2016, 09:24 AM   #11
Brake dust & black wheels
I have the black wheels ('15 GT Premium w/PP) and they can get very dull with brake dust, maybe not quite as noticeable as on yours, but frustrating just the same. I put somme AA break dust cleaner on the left front wheel yesterday and it looks pretty good. Not sure how effective it will be in reducing the build up of dust though.
Old 03-04-2016, 05:12 PM   #12
Centric Posi Quiet ceramic pads. Had chrome rims and then anthracite. Never once had a brake dust issue with those pads. Ever.
Old 03-04-2016, 05:54 PM   #13
Slater2111's Avatar
I haven't noticed much with hawk HPS pads.
2003 GT: JLT CAI, summit 75mm TB, C&L plenum, 24# injectors, Mac Prochamber, SLP LM1 cat back, 3.73 Gears, FR500 Diff, FR500 diff cover, Jmod trans and shift kit, Max Motorsports subframes, Koni oranges front and rear, DBA discs front and rear, shrader performance rear seat delete, APSX D2 wideband, MPT happy customer.
Slater2111 is offline   Reply With Quote
Old 03-04-2016, 09:53 PM   #14
Steve96's Avatar
Go ceramic or just clean them often
1996 GT
Old 03-04-2016, 11:42 PM   #15
Also go Rockauto for your brake parts. I have had multiple white box parts store crap brand rotors have runout issues. Tried and true combo for me is Raybestos rotors and those Centric pads I mentioned a few posts above. Always from Rockauto.
SS Brake Line install Horseplay Pre-2005 V6 Mustang 7 12-29-2013 06:03 PM
Cobra brake swap twotone01 Pre-2005 V6 Mustang 17 08-13-2012 02:06 PM
12V Relay Brake Bypass? ColeJohnson Mustang Audio & Video 8 01-26-2012 09:22 AM
Lowering the 2012 5.0 Brembo Brake Package avengnd 2011-2014 Mustang GT 33 10-28-2011 07:47 PM
Most Popular Brake Pads Brent 1996-2004 Mustang GT 18 09-18-2011 10:29 AM
04:32 PM
