Cam build list - Mustang Evolution
Old 02-27-2013, 09:05 PM   #1
Matticus's Avatar
Cam build list
Just want to get a full list of everything needed/recommended for a cam upgrade. Looking at the stage 1 comp cams. I know you need:
Comp cams valve springs
Adjustable cam gears
Slightly bigger injectors, probably 24-30lb
Dyno tune
What else do I need to add?
---------- Post added at 10:05 PM ---------- Previous post was at 10:03 PM ----------
Also, I may go ahead and go stage 2 if it doesn't require too much more.
Matticus is offline   Reply With Quote
Old 02-27-2013, 10:40 PM   #2
Slow4V's Avatar
Or go with some real cams ..
Anderson motor sports ( Made by Ford ) Stage 1 camshafts don't require you to change springs/retainers , etc.
and have been proven to out perform other competitor company's..
Check them out
Old 02-27-2013, 11:35 PM   #3
If you want a good sounding lope, CMS Stage 2 sound the best to me. Best sounding lope I've heard
Old 02-27-2013, 11:51 PM   #4
03fastblack's Avatar
Check them out
So you're saying you can just replace the camshaft an that's it with the Anderson cams?
03fastblack is offline   Reply With Quote
Old 02-28-2013, 06:08 AM   #5
Matticus's Avatar
Check them out
Got a link? Lol
Old 02-28-2013, 07:49 AM   #6
goodwinta1's Avatar
http://www.andersonfordmotorsport.co...Camshafts.html
I think this is the site he was talking about.
goodwinta1 is offline   Reply With Quote
Old 02-28-2013, 08:13 AM   #7
CodyNelson's Avatar
Region: West Virgina
Anyone who goes through the hassle of cams without getting springs and retainers is crazy. AT LEAST do the retainers unless you want your valve train to sound like a seeing machine
Old 02-28-2013, 10:57 AM   #8
Matticus's Avatar
Am I missing anything for a solid cam build?
Old 02-28-2013, 05:23 PM   #9
CodyNelson's Avatar
Nope looks good. I would suggest comp 270 stage 2 cams though. They are a great cam for the 2Vs and have an amazing idle. Plus if you ever get a blower they are great blower cams too
Old 03-02-2013, 08:35 AM   #10
Matticus's Avatar
75mm TB once I get the cams in? Or should I still go with a 70?
Old 03-02-2013, 08:37 AM   #11
goodwinta1's Avatar
From what I have read the 75mm TB is a must do if you are going to do a tune anyway, even without a cam.
Old 03-02-2013, 12:07 PM   #12
mhobbs's Avatar
ya get a 75mm u wont regret it..and Ive been told no need for bigger injector till you hit 350 RWHP. And also I used adjustable crank gears instead of cam gears..made by trick flow.
mhobbs is offline   Reply With Quote
04:03 PM
